[C1] 1959 283 Fan belt hits lower rad hose
#41
The plate is shown in the AIM drawing and has its own part number, but you have to be looking for it, it isn't real obvious..
Doug
Doug
#42
Yes, that's the plate I was talking about in Post #24.
#43
Yes Frankie, I am seeing it your way. All the brackets everyone speaks of are there, unmoved from the first time we took off the generator. The only thing we removed was the generator and the belt. The reason we took it off was to replace a bad voltage regulator.
#44
Received 2,343 Likes
The tach drive housing hitting the manifold tells me the generator may be assembled incorrectly.
Remove the generator, compare it to the photos and clock the stator housing of the generator to match how the proper alignment and mounts look.
#46
On #28;the fourth picture, I don’t understand the setup. We have the u bracket bolted through the backing plate into the manifold. It looks like the 4 hole plate is in the manifold and the u bracket is bolted to the plate. The picture looks totally different.
I have the backing plate, the picture you can see with the extra set of holes on the bottom. You can even see the belt resting on the frame in one pic and the tach unit hitting the manifold.
Tach unit close to manifold
4 holes bracket between u shaped bracket and manifold
Belt touching frame
Belt touching frame
#47
Compare the above photo, to the photo below:
Can you see where the tach drive end of the generator is assembled incorrectly (clocked 180 degrees off)?
Last edited by 63 340HP; 02-12-2019 at 01:09 PM. Reason: Someone else oon CF(?) deleted one photo in my quote, the wrong photo to contrast the differences between the two generators.
mike coletta (02-13-2019)
dcamick (02-12-2019)
#49
You're right - that's what the book shows and how mine is set up. Your brace looks contorted though.
#51
You don't need to show any more close up pictures of how close it is. That's obvious. Can you take a picture from the rear of the generator, showing the mount and exhaust, but NOT so close up. Your adaptor plate can't be right. It has to be bolted to the exhaust with the top two holes closer to the front of the car. That moves the generator forward and up as it should be. Then the lower bracket for the generator bolts to that. Then the generator to that. Again the close up pictures are deceiving, back the camera away and show the back side of the generator, it looks like the end plate is mounted 180 out, but need better pictures. Look at the picture posted with the adaptor plate mounted to the exhaust manifold, that's the way the holes MUST be
The following 2 users liked this post by 65GGvert:
C.T. (02-11-2019),
#53
Great. Just note that the generator doesn't bolt to the exhaust. It bolts to the plate that bolts to the exhaust. the two bottom holes in the plate bolt to the exhaust and then up and toward the front are the top two empty holes where the generator bracket bolts. Refer to that picture that shows the plate bolted to the exhaust with nothing else held on by those bolts.
#54
Looking at the one pic, the OPs flat adapter plate is on upside down. OP will probably need a longer fan belt once corrected. Flipping the plate may have been the way someone made a too short belt, fit. OP will probably also want a new lower rad hose once problem is corrected.
Doug
Doug
#56
Tried flipping the plate but it just moved the generator forward so now the pulleys no longer line up. Went back to the rebuilder and believe it or not, he passed away 2 weeks ago. Is the tach unit flipped by just the 2 screws or do I have to do something inside too?
#57
Haven't been keeping up - but here is the TSB on "flipping' the tachometer drive:
#58
If you still want help with this, you're going to have to remove the generator and take a picture (not too close up) of the adapter mounted to the exhaust manifold, then a picture of the generator mount. Your generator is way too close to the engine (exhaust manifold) and something is mounted incorrectly or omitted. When the plate is mounted the two empty holes must stick UP and forward like in this picture.
#59
Also, in your pictures you show the front adjusting bracket behind the ear on the generator. The drawing also shows that. If the drawing is right, then my bracket is in the wrong place. I don't believe it is because the bolt has to screw through the slot and then into the generator threads. The bolt head is at the front and threads to the rear, opposite of the drawing. This is a close up of my mount which has always been fine and is opposite of the drawing shown earlier.
#60
Another angle of the bracket to adjust belt tension
