66 Power Steering help
Old Feb 14, 2019 | 06:57 PM
Early66L72's Avatar
Early66L72
Default 66 Power Steering help
I need some help from the collective on my pwr steering. Everything is new and put in using the AIM and the new pwr steering control valve ballanced per all documents. so what it does is it works normally from center to the right all the way to the stop. then when you go to the left it works normally for 2/3 to 3/4 of the travel then takes off on its own... any ideas from the collective??? its a 66 L72..
thanks for any help jcw
Old Feb 15, 2019 | 10:05 AM
tbarb's Avatar
tbarb
I think you should back up and check the valve adjustment like the book explains. Disconnect the slave cylinder rod from the frame bracket and remove the dust cap on the valve, start the engine and center the valve spool.
After this adjustment if you get no joy there may be a problem with the valve, I would call the supplier.
Old Feb 15, 2019 | 10:16 AM
Early66L72's Avatar
Early66L72
tbarb, yep, went thru that step by step and it still does the same thing. any other ideas? it's a lone star control valve and they are usually very good..
jcw
To 66 Power Steering help
