[C1] Adding dual master cylinder
What years for the Mopar master cylinder? Would to see a diagram, too.
Received 1,283 Likes
40ZR1 (02-20-2019)
The one I used was listed as being for a 1968 Plymouth Roadrunner, 6.3L
CARDONE SELECT 131323M
https://www.rockauto.com/en/moreinfo...=1240478&jsn=8
CARDONE 101323M
https://www.rockauto.com/en/moreinfo...1240478&jsn=13
I think the only difference is that the 131323M is listed as “Condition New” whereas the 102323M condition is not listed so I assume it is rebuilt.
Charles
CARDONE 101323M
Charles
Here is a set of schematics for an adapter plate developed by one of the forum members and posted in a thread a while back.
With a special thanks to wmf62 for posting these....
Kerrmudgeon (04-08-2019)
Below is a picture of the label on a Dorman MOPAR MC that works. Notice the other replacement part numbers.
64Corvette (02-20-2019)
Received 6,528 Likes
C2 of Year Finalist (track prepared) 2019
https://www.zip-corvette.com/53-62-p...-1in-bore.html
Is there install straightforward?
Seems like a good alternative.
Too, if the car is a '58 - '62 with fuel injection and the stock air cleaner is in place, there is no room for that assembly.
jerry gollnick (02-22-2019)
It's a good system and I don't mean for my anecdote to be a criticism of it. In fact, I think that's a really good option for adding power brakes to a C1.
Jim
Jim, what's a hydra boost. Got any pics. I just rebuilt my complete brake system, replaced everything but I would like to add P/B. the mopar master looks best.
cj
cj
#33
A hydroboost (and I may be misspelling the name), is plumbed into the hydraulic line. It senses line pressure out of the master cylinder and then boosts the pressure seen by the wheel cylinders. Because there is hydraulic plumbing involved, installation is more involved than with a traditional PB booster but the advantage is that you can locate the booster anywhere.
A quick on-line search fails to turn up a picture of one of the old Hydroboost units. However, I have two of them and if no one else comes up with a picture, I'll snap one of one of my boosters and post it.
Jim
40ZR1 (02-22-2019)
#34
Here is one that I fabricated for my '59 , but decided not to use it. The hydroboost uses hydraulic pressure from the power steering system to furnish power to the master cylinder. I didn't particularly like having the extension tube, plus I did away with the power steering pump.
Charles
Charles
40ZR1 (02-22-2019)
#35
Charles
Charles
The Hydr[a,o]boost system to which I'm referring develops boost from manifold vacuum. However instead of amplifying mechanical force, it amplifies hydraulic pressure directly.
Jim
40ZR1 (02-22-2019)
#36
#37
There was a 1959 Corvette that was discussed in the last year or so that had dealer installed power brakes, but I do not remember anything about power steering.
I am trying to find that thread now.
#38
Found it...
There was a 1960 Corvette that was discussed in the last year or so that had dealer installed power brakes, but I do not remember anything about power steering.
Here is the car and the details on the add on Hydrovac power brakes
Bendix Hydrovac installed by dealer on a 1960
Paperwork for that 1960 with P Brakes listed
A restored Bendix Hydrovac booster
The following 4 users liked this post by emccomas:
#39
I have the Mopar master cylinder on my C1. Fits and works very well. But, if you have converted to disc brakes and don’t want power, a master cylinder with a 7/8” bore would be a better choice.
#40
[QUOTE=jv04;1598912544]
[/QUOTE
Why are the center lines of the bores different? Is it so that top holes of Mopar M/C and vette M/C don't interfere? If I used a 1/4" adapter plate would I have add 1/4" to the M/C push rod?
Thanks for the pics of the hydra boost, have not seen one before. And I don't want one!
CJ
[/QUOTE
CJ
