Bare glass underbody on 1963's only ?
So knowing GM didn't paint the 63's under body from the factory I decided to undertake a detour job before setting the body back on the frame. This SWC had the usual undercoating in the wheel wells and random rattle can paint in other parts when I got it. But mostly bare glass still visible. Now .It's taken months ,some light sanding, 2 coats of West systems epoxy resin to seal it ..... it's finally done. I'll never do that again !
GR - Nice job; what epoxy resin did you to seal the bare glass with, and can you describe the methods employed sanding and applying the resin - Thanks - GV
So knowing GM didn't paint the 63's under body from the factory I decided to undertake this job before setting the body back on the frame. My SWC had the usual undercoating in the wheel wells and random rattle can paint on other parts when I got it, Some bare glass was still visible on some sections . So.....It;s taken a few months but after some light sanding and 2 coats of epoxy resin to seal it ..... here it is finished. product .
Yep ......Sanding fiberglass overhead is a real joy ! I wet sanded with 180, just enough to get the light clean color back. Then followed up with West Systems 2 part epoxy. The cure time requires it to be done in sections w/ greater than 70deg F temp..
I applied it with a light bristled brush. What a pain . You need face shield and Tyvek suit, Oh careful not get it on your skin...... because it does burn ......
If I were to do it again (which I wont) just spray it with clear and be done.
