67 tail light problem
Old Mar 2, 2019 | 04:30 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
You better never go hunting for two weeks in the Colorado mountains !
Old Mar 5, 2019 | 12:51 PM
deejaydu's Avatar
deejaydu
I checked with a meter and found that the brown wire from the switch to the rear block connector is good. Also checked the switch with the meter and found that the switch is good. Ckecked the brown wire fron the rear block connector to the tail lights and found that their is no continuity in that wire. I found corrision in the driver's side inboard tailight. I cleaned it all up and replaced the bulb. I also did the license plate light and found that it was in good shape with no corrision and I replaced the bulb. I am in the process of doing the rest of the lights now to make sure that they all have good connections and bulbs. The two that I have done did not fix the problem. Will report back back when I am done.
Old Mar 5, 2019 | 01:58 PM
65GGvert's Avatar
65GGvert
don't forget to check that junction I mentioned a few posts back about where the three brown wires come together at the license plate light.
Old Mar 5, 2019 | 04:06 PM
deejaydu's Avatar
deejaydu
Exactly that is what I am hoping is the problem. I haven't found that junction yet but I will. Thanks for all of your help.
Jay
Old Mar 11, 2019 | 11:32 PM
deejaydu's Avatar
deejaydu
Here is what I have done to the rear of the car. I have cleaned all of the tail light and license plate sockets of any corrosion and replaced all of the bulbs. I have found where the brown wires along with a black ground come out of the harness at the license plate. I have not found where the brown wires all connect. Are they soldered together or just twisted together? Do I have to unwrap part of the harness at the license plate to see the connection? I am making progress but still have not found the problem. All brake lights and turn signals work correctly as well as the backup lights.
Jay
Old Mar 12, 2019 | 07:43 PM
deejaydu's Avatar
deejaydu
ttt
Old Mar 13, 2019 | 08:50 PM
65GGvert's Avatar
65GGvert
If you're sure you have it at the brown wire coming out of the connector, the problem is between the two red arrows. It's a straight piece of wire from front to rear.
Old Mar 13, 2019 | 09:24 PM
deejaydu's Avatar
deejaydu
Jack that is exactly where I am looking. I will find it and fix it. Great picture. Thanks again
This Forum is great .
Jay
Old Mar 30, 2019 | 12:09 AM
deejaydu's Avatar
deejaydu
Problem fixed. Found cause was old repair of brown wire broke again. Now it is properly fixed.
Thanks for everyone's help
Jay
