valve covers
Old Mar 13, 2019 | 10:15 AM
lignell's Avatar
lignell
Navigator
Default valve covers
i have a 64 corvette 327 300 my valve cover has peeled and I want to repaint it not sure of the color,it looks like an orange color it has a gloss and it needs to be heat resistant thank you
Old Mar 13, 2019 | 10:22 AM
Factoid's Avatar
Factoid
VHT SP123 Chevy Orange high temp engine paint. If possible,once you prepare the vc and paint it, cure the covers in an oven before reinstalling them. BTW, in my experience it is not a perfect color match, but so close no one will see any difference.
Old Mar 13, 2019 | 12:02 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Be prepared for the stark contrast of your new painted valve covers against the rest of the supposed unrestored engine compartment. This has led to body off restorations. Don't laugh, it's a fact. Some people call it, "while I'm doing this I might as well do that"! Dennis
Old Mar 15, 2019 | 05:37 PM
Godholio's Avatar
Godholio
Project Creep is insidious.
Old Mar 15, 2019 | 08:58 PM
ghostrider20's Avatar
ghostrider20
Take th covers to a machine shop and have them bead blasted. The paint will adhere better. If the covers are too shinny and new when done, a rag and some brake cleaner, gently wiped over the surface will age them. Repeat the wiping stock get desired appearance.
Old Jun 22, 2020 | 01:42 AM
jusplainwacky's Avatar
jusplainwacky
I have a 58 and powder coated my valve covers and they look as good as the day I did them.
I bought myself a labratory oven off craigslist and did my own.
The comment above about oil being an issue is not true...you just have to clean them well. I use Berryman's carb cleaner...works great.
Also, you can get Chevy orange color in powder and it's an excellent match. I also powdered coated the front engine bracket that is between the engine and water pump, oil pan, my original tach drive generator housing before I sent it off to be rebuilt, my transmission housing, fly-wheel cover, wheels, intake manifold. and god knows what else.
The nice thing about powder coating is that it's very durable, cleans easily, impervious to just about anything that gets on it. Cleaning my oil pan is a breeze, a little soap and the grime wipes right off...just like everything else powder coated.
To valve covers
