Just started playing around on my newly acquired 67 convertible today. Had to replace the alternator, as it wasn't charging. Once replaced and putting out some "juice", the headlight motors that hardly worked at all before the alternator change, now started to respond to the switch. Funny thing happened though, one would go up as the other went down and vice versa when pushing the switch the opposite way. Driver side worked correctly passenger side did the opposite. Seems like a simple miswriing issue but wondered if anyone saw this before. I have little prior history on work being done. I didn't have time today to troubleshoot wiring but just thought I'd toss it out there if anyone had experienced it.
thanks,
Mike
Both motors should open the buckets when the dash switch is pushed up so whichever one does NOT do that has the wires switches in its connector or elsewhere— an easy fix.
Look for the yellow (or black with yellow stripe) wire and the green wire going to the passenger side motor. Those two wires are switched somewhere between where they plug into the connector and where they join up with the wires on the driver's side to split off to the passenger side if the passenger side headlight is truly going up when you hold the rollover switch in the down position. Make sure the black ground wire is connected, I don't think the voltage could feed back to the driver's side motor winding if the ground was disconnected and cause it to move wrong, but it only takes a second to look.
65GGvert, I recently rebuilt my headlight motors and gears along with new wiring sockets. In my haste of pulling these motors out I failed to record where the green wire and black with yellow stripe wires went on each one. When I reinstalled them I noticed in the wiring diagram that the drivers side was wired one way and the passenger side was just the opposite. The sockets are kind of a modified T shape and where the green wire is on either the stem of the T or the cross bar portion, they are just the opposite on the other side. I am about a week or two away from putting the battery back in after having done a lot of cleaning over the winter and don't know what to expect. Does this sound right to you? I have the hood off and they are easy to get to now, so if I have them wrong I can easily correct it now. Are these right or wrong? Thanks.
Stock, the green wire goes to the "tee top" on the passenger side and on the "stem side" on the driver's side. They are different, as you said.
Thanks for confirming this for me. I hope I didn't steal this thread to answer my question, but the OP may have both of his sides wired the same. This may help.
Dick, The wiring diagram should answer all of your questions. If you have a mechanic or a friend that is doing the work for you a copy of the diagram would be good to have. Ple
I experienced somewhat the same thing in my 67. Make sure the battery is well charged. Try it when the motor is operating. Sometimes worn headlight motors do not work properly if they don't get enough power. One goes up, the other stays down. etc. I had this problem. Both work fine now. If problem persists and it's NOT a wiring issue, you may have to rebuild or replace the motors due to age.
Everything you said is true. However, his motors are running in opposite directions with the same movement of the switch, not sticking or intermittent. 12v has to be getting to the wrong place.
