wipers
Old Apr 5, 2019 | 12:27 PM
fever1's Avatar
fever1
Default wipers
Help, on my C2 convertible which wiper arm goes on top of the other, Left on top or Right on top thanks.
Old Apr 5, 2019 | 12:31 PM
mike coletta's Avatar
mike coletta
Passenger side on top.
Old Apr 5, 2019 | 12:33 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
The driver's side should be about 1" off the lower stainless trim and the passenger side 1" above that - both should be nearly horizontal - original arms had a screw in the side to adjust the "horizontal-ness"...
Old Apr 5, 2019 | 12:44 PM
fever1's Avatar
fever1
Thanks, there is my problem, Mine has the drivers side on top and binds with the other, I'll fix, knew it was, right.
Old Apr 5, 2019 | 06:18 PM
Oaker57's Avatar
Oaker57
With mention of an adjustment, I am wondering if there is an adjustment for how far the arm swings in it's arc, as in my driver side travels to far and goes out over the window trim, but yet comes to rest perfectly at the bottom when shut off. Kind of weird that it travels to far in one direction. Other wise they come to park as described above, Any ideas?
Old Apr 5, 2019 | 06:58 PM
Frankie the Fink
Army
If the wiper arm is the proper length - then the adjustment above should take care of that....there is no adjustment for the arc...
Old Apr 5, 2019 | 07:14 PM
Oaker57's Avatar
Oaker57
Well both of my wipers are the same length, which is correct as far as I know, and it's the whole blade that goes to far, not just the tip end (which would be the result of it being to long I believe). Could something be worn out in the swing arms that would allow one travel direction to go to far. It's had me stumped for awhile, but since they're rarely used not the first thing on the list.
Old Apr 5, 2019 | 08:03 PM
Frankie the Fink
Army
I have heard of the wiper arms being hooked to the pivot points incorrectly causing similar problems.
To wipers
