Starter Diode
1966 Corvette smallblock
I realize that this is beating a dead horse but I found conflicting information regarding this.
I have a new Power Master 19100 Starter with only one wire on the solenoid.
This car has a ballast resistor.
I am going to install a diode between the engine side +12V large post to the wire that originally went to the "R" terminal.
So far so good.
1) One source says to put the diode band toward the starter post.
2) One source says to put the diode band toward the "R" wire that back feeds to the coil.
3) One source says to use a 3A 400V diode.
4) One source says to use a 10A 250V diode.
Please pick only two numbers from the above list.
Thank You
LOL
I'd connect the non-banded end of the diode to the "S" terminal of the starter.
As to which diode, more current capability is better. However so is greater reverse bias Voltage capability. Of the two diodes you list, I'd go with the 3A, 450 V device.
Jim
You definitely want the banded end of the diode pointing at the coil.
Here's a simple explanation of current flow through a diode. An easy way to remember is the diode symbol, current flows with the arrow and not against the bar. The bar is the banded side.
https://www.autodesk.com/products/ea...iode-led-work/
In the old days, we talked about either electron flow or hole flow. This had to do with the direction of current flow. Today, the standard is electron flow meaning that current flows from - to +. The schematic symbol for a diode is an arrow with a line drawn across the tip. The band on the physical diode represents the line. Consider the arrow pointing towards the line to indicate the direction that current will not flow. By placing the band towards the - or non + side, current will flow when +12v is applied to the opposite side of the band. I’m sure this is more info than you wanted, so I will continue!
By placing the diode connected to the large +12v post on the starter, you will have +12v to the diode at all times. Not an issue if your points happen to be open when the engine stops turning. However, if the points are closed current will continue to flow draining your battery and perhaps damaging your coil. By using the S terminal, +12v will only be applied when the key is in the START position effectively bypassing the ballast resistor during cranking.
Semiconductor diode schematic symbol: Arrows indicate the direction of electron current flow.
When placed in a simple battery-lamp circuit, the diode will either allow or prevent current through the lamp, depending on the polarity of the applied voltage. (Figure below)
Diode operation: (a) Current flow is permitted; the diode is forward biased. (b) Current flow is prohibited; the diode is reversed biased.
When the polarity of the battery is such that electrons are allowed to flow through the diode, the diode is said to be forward-biased. Conversely, when the battery is “backward” and the diode blocks current, the diode is said to be reverse-biased. A diode may be thought of as like a switch: “closed” when forward-biased and “open” when reverse-biased.
Oddly enough, the direction of the diode symbol’s “arrowhead” points against the direction of electron flow. This is because the diode symbol was invented by engineers, who predominantly use conventional flownotation in their schematics, showing current as a flow of charge from the positive (+) side of the voltage source to the negative (-). This convention holds true for all semiconductor symbols possessing “arrowheads:” the arrow points in the permitted direction of conventional flow, and against the permitted direction of electron flow.
And then GG had to go and bring in PN junction theory!
Sorry, it’s a slow day here at the ranch.
What did you think the wire/diode was for?
Doug
I would NOT mount the diode on the starter or, for that matter, anywhere in the engine bay.
My suggestion is that the OP install the diode in the passenger compartment and run wires from the diode, through the firewall, to the coil (+) terminal and to the starter "S" terminal.
Extra credit will be given if the OP splices into these two circuits at points behind the instrument cluster, thereby avoiding unsightly extra wires in the engine bay.
Jim
