[C2] Missing Piece on Door
Old Apr 15, 2019 | 09:34 AM
59BlueSilver's Avatar
59BlueSilver
2023 Restomod of the Year Finalist
Default Missing Piece on Door
I'm missing a piece on the inside of both doors. I don't know what it's called or where to get it. Also, how does it attach?
Old Apr 15, 2019 | 09:37 AM
Frankie the Fink's Avatar
Frankie the Fink
Army
Its a corner piece and Long Island sells them - what year car ? It makes a difference...
You can see them here - if somebody has hacked up your window channel though you may not be able to attach them...
Old Apr 15, 2019 | 09:56 AM
Tampa Jerry's Avatar
Tampa Jerry
Have you checked the inside bottom of your door? They can fall off and be in the door cavity. They may be different for the 63s. They clip on to the window via clip. I don't remember what they are called, but I think Paragon has begun reproducing them. I think I found the last two good used pieces about 15 years ago. Jerry
Old Apr 15, 2019 | 09:57 AM
gbvette62's Avatar
gbvette62
What you're looking for is the 64-67 coupe inner door corner molding. They're available as a repro for about $75 for the pair, and come with the short felt strip attached to them.
Old Apr 15, 2019 | 10:17 AM
Frankie the Fink
Army
63s are different and no correct repros are made - most adapt the 64 garnishes.
Old Apr 15, 2019 | 11:37 AM
59BlueSilver
Yes, thanks, found them at Paragon as you said.
Old Apr 15, 2019 | 11:39 AM
59BlueSilver
For my 65. I looked for them for 30 min. on LI’s website. Difficult site to navigate, never did find them.
Old Apr 15, 2019 | 11:42 AM
John BX NY's Avatar
John BX NY
FWIW...We called it the door glass run channel when i worked in GM plants in the 2000's
Old Apr 15, 2019 | 01:49 PM
Frankie the Fink
Army
LICS part number: 42-47E
Old Apr 15, 2019 | 03:53 PM
gbvette62's Avatar
gbvette62
The OP wasn't looking for the door glass channel. He was looking for the stainless trim piece that fills the space between the bead on the inner door glass wipes on the door panel, and the bead on the pre-bent, door glass rear vertical felt channel.
Old Apr 15, 2019 | 04:01 PM
59BlueSilver
That’s it alright, thanks Frankie!
Old Apr 16, 2019 | 09:11 PM
Redbird's Avatar
Redbird
2021 C2 of the Year Finalist - Unmodified
2016 C2 of Year Finalist
Here it is with Frankies help. I just bought a pair for my 64.
Old Apr 16, 2019 | 11:03 PM
59BlueSilver
Pricy little thing, isn’t it!
Old Apr 17, 2019 | 06:53 AM
Frankie the Fink
Army
Yes, not cheap, and care needs to be taken when installing them - leave no sharp metal exposed where it can scratch the window when operating it.
Old Apr 17, 2019 | 08:31 AM
59BlueSilver
Thanks for that tip, Frankie. How does it attach, I see a fastener hole so does it take a sheet metal screw and should I have a nutplate? Can I install it while in the car?
Old Apr 17, 2019 | 08:44 AM
Tampa Jerry
The part snaps into the hole on the door. There is a green nipple that spreads out to attach it to the door. It can be installed without removing anything. Jerry
Old Apr 17, 2019 | 09:41 AM
Frankie the Fink
Army
It’s been a while but I thought the corner was riveted to the rest of the garnish and the split nub secures it to the door.
To Missing Piece on Door
Old Apr 18, 2019 | 08:00 AM
mike coletta's Avatar
mike coletta
63 is different (as always). Go here, https://licorvette.com/window_channels_corvette.htm
Old Apr 18, 2019 | 08:10 AM
Frankie the Fink
Army
What I got from LICS when I ordered the channel was stapled (not riveted) - my mistake:
Old May 11, 2019 | 11:25 PM
59BlueSilver
I cannot get this piece inserted into the hole! Is there a rubber insert or something? I’ve ground down the split nub but have to go much farther to get it in. And then once I make it small enough to fit the hole, not sure it will stay. Any ideas?
