[C1] another dual quad question
Old Apr 25, 2019 | 02:17 PM
dgsmith's Avatar
dgsmith
Default another dual quad question
Were any changes made to the front carburetor, other than removing the choke, in a 56-61 dual set up? Did the front carb retain idle circuits? Can any Corvette WCFB be converted to a front carb.?
Old Apr 25, 2019 | 02:20 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
The choke on original Corvette WCFB front carbs was not removed - it never existed - the way to check for a front carb "clone" is to see if there are plugged holes for the shaft for the choke plate - a giveaway..
Yes it has an idle circuit and if you look at the service manual it tells you how to adjust idle speed and mixture for BOTH carbs in a dual quad setup...
Nearly any single carb WCFB can be "dialed in" to work up front - there are many cars running around with that setup.
Here is an example of clones for sale on eBay right now:
Well done clones will have counterweights changed for the dual quad setup and often metering rods and jets.
Here are my "real deal" 270 hp dual quads:
Having said all that there was one application I read about where BOTH carbs had chokes but memory is dim - Cadillac ? Buick ? I don't recall.
