Leak from Holley float bowl casting plug?
Hi,
Just installed my new fuel pump and fired up the '67 for the first time this season.
I have a 4160 and have a jet of fuel spraying out from the casting plug on the top of the primary fuel bowl at the fuel inlet, some Holleys have a float adjustment screw in that position.
I read online to fix it with JB Weld, anyone try it? I want to be sure its a permanent fix, fuel spraying on a hot engine is not one of my favorite things.
Paul
Paul
Received 1,395 Likes
2021 C2 of the Year Finalist - Unmodified
2015 C3 of the Year Finalist
Clear epoxy will fix it, just be sure to get the area very clean and let it dry completely before applying.
Fawndeuce (05-05-2019)
Received 3,043 Likes
St. Jude Donor '05
x2 its not under a lot of pressure that will hold fine indefinitely
I've had that same plug leak on my 4160. I removed the bowl and using a 1/4" socket of that particular size, lightly re-peened the plug. Those plugs are swedged in place. Just be sure to back up the float bowl in that area with a bar or solid object of some kind as you don't want to distort or crack the bowl. It hasn't leaked since.
It's not a original 3810 bowl so you can epoxy it or get a bowl from a 1966 Holley 3367 that has the external adjustable float.
Thanks for the responses guys.
There is pressure in that area, the pin stream of fuel was arching about 2 ft in the air, the plug is located in the fuel passage from the fuel line.
I took the bowl off and the float out, I can move the the plug a bit by pushing up from the inside with a right angle pick. I'll try re-peening it, maybe also some JB Weld.
Paul
Paul
Paul, however you decide to fix it just be careful with gasoline. Buy a new bowl, peen the flange tight and j&b weld, whatever. The last thing you want to do is have that liquid fuel spray on a hot motor.
It's only a few psi, if you have an original mechanical fuel pump, but a small hole looks like a geyser.
Received 2,182 Likes
2015 C2 of the Year Finalist
