That is a rare prototype / experimental piece - the 0 preceding the casting number is your clue
That was designed to be used in non - Corvette application - most likely Chevelle.
The rear carb is dropped down to fit under the cowl / firewall.
Date code - early 1967
I saw one of these at Smokeys installed on one of his NASCAR Chevelles
that makes sense. Place I got all the parts from, I also got a couple rare junior johnson intakes
Is that when Junior decided to make his "own" intakes - trying to improve on what was already "out there"
I believe Smokey had one - can't recall details - it was a bit different / weird LOL
