Fuel for High Performance
Oxygenated fuels have a bit less energy than non-oxygenated fuels - one to three percent depending on the amount of oxygenate, which varies during the year. In CA RFG II has oxygenate year round, but more in the winter than summer. In many parts of the country, oxygenates are only used during the winter.
The EPA and CA have approved up to 10 percent ethanol by volume, and all OEM's approve this for modern cars. MTBE may be blended up to 15 percent by volume. Modern fuel system elastomers have be upgraded to handle "gasohol" and MTBE, so if your rubber fuel lines are less than fifteen years old, they will not deteriorate due to ethanol. If they are over fifteen years old, replacement would be highly advisable just on the basis or their age.
Since MTBE is being phased out, within the next few years the only common oxygenate with be ethanol.
I don't buy the claim that Arco is much different from any other brand of gasoline because of both the RFG II blending requirements, and the fact that most retailers buy generic gasoline from independent refiners. The use of ethanol as an oxygenate in Northern CA is more common than in Southern CA, and usually there is a sticker on the pump stating whether the fuel contains either MTBE or ethanol.
The above information is from research I did a few years ago when RFG first came into use, and the primary source was discussions with personel from the Chrevrol Research facility in Richmond and documentation that they provided me.
Duke
[Modified by SWCDuke, 5:15 PM 11/7/2002]
...lesse here, gimme a box of slides and wheel me around to corvette club meetings...now that i know ONE regulation, i'm an expert.......
...no offense intended to the poster but that "consultant" better keep his day job...and THIS is exactly why we have this forum...to detect :bs
[Modified by Kid_Again, 12:34 PM 11/7/2002]
Now they have done away with leaded gas, and Super is only 91 Octane here in California. I've been OK with this so far. I have added 100 Octane gas when at the track, but I've also run with pure unleaded with no problems (fromthe gas at least).
Kid Again, the specialist's "day job" is fuel and engine analysis, not making second guesses on Internet forums. :D
[Modified by Kid_Again, 12:34 PM 11/7/2002][/QUOTE]
Just checked the owner's manuals in both of our '02 cars - my Dodge Caravan is "E-85" capable (will run on ordinary 87-octane or on "E-85" fuel containing up to 85% ethanol), although the manual points out that degraded driveability and hard starting is common with E-85, and fuel economy will drop 30% or more on E-85, and E-85 should not be used in temperatures below 0*F. It also points out that fuel containing Methanol should NEVER be used, as it will void the warranty, and it goes on to point out that most "octane enhancer" additives contain a very high concentration of Methanol, which will damage the fuel system.
My wife's Sebring convertible (different engine) is NOT E-85 capable; the manual says fuels containing up to 15% ethanol ("gasohol") are fine, and has the same caution about "octane enhancer" additives.
As Clem has pointed out many times, "octane enhancer" additives eat the plating off the inside of carbs he has been given to rebuild; the OEM warnings about "octane enhancer" additives are obviously there for a reason - they should be avoided.
...please don't second guess me on the regs
No second guessing going on here, and no offense meant. Just relating what I heard from a knowledgeable person. 'Nuff said, from my perspective.
63FI....kcwild62 has already expressed interest so i'd like to honor that request first...btw, i have 8 qts Podell's TEL and 5/6 12 oz. cans of Supreme 130 - each one worked equally well for me and i generally used only half the recommended amount because of what i read here about the corrosive properties of some of these additives...but that amount was adequate to completely stop detonation with the big block during august - and those pistons were perfectly good enough to be put right back into the engine during the rebuild...
....i know very well where hamilton square is...i used to shop at harry's....i am just down route 295 from you
[Modified by Kid_Again, 7:28 AM 11/8/2002]
I'm building a replacement BB motor now, for next season... i'll be shooting for ~ 11:1 with the big iron merlins... after I get everything fit up, it might even be a tad more :yesnod: I can't see spending $8000, or so, on an big strong engine, then bitching about a few extra bucks for quality fuel.
