Upper control arm stud nuts
Old May 23, 2019 | 08:39 PM
C2CorvetteBob's Avatar
C2CorvetteBob
Default Upper control arm stud nuts
It looks like 63-65 used tall nuts and lock washers on the upper control arm studs and 66-67 use a different nut without a lock washer. Can someone with an AIM confirm this please?
Old May 24, 2019 | 12:52 AM
waynec's Avatar
waynec
I only have the '63 assembly manual
lock washer 186418
nut 3722853
Assembly manual does not give size/dimensions
They're cheap, buy both year ranges
... https://www.corvettepacifica.com/pro...-pieces-63-65/
... https://www.paragoncorvette.com/p-35...d-nut-kit.aspx
... https://www.corvettepacifica.com/sea...&submit=SEARCH
Old May 27, 2019 | 08:06 PM
JohnZ's Avatar
JohnZ
That's correct - if you had an Assembly Manual or an NCRS Judging Guide, that's what it would tell you. '63-'65 used a conventional 3722853 hex nut and split lock washer, '66-up used a prevailing-torque 9422300 lock nut without a lock washer.
To Upper control arm stud nuts
