MSD-6T Ignition
Needs some advice. I have a MSD-6T installed on my 63SWC (327 engine with distributor). Last year, the engine would turn over, but would not start. I tried all the usual, still wouldn't start. I noticed the red battery cable from the MSD 6T was swollen. I cut the piece out, cut into the swollen area and noticed it looked like "SWOLLEN" blue plastic!!
The MSD 6T I have doesn't come apart, back looks to be permanently affixed. The wiring harness goes directly into the box.
Here is the question: I would like to just cut off the "bad" part of the red battery cable from the MSD box since I can't access the end of the cable within the MSD box itself. I would like to "splice" (via a crimped butt connector) a new piece of cable with the piece of the older cable. I ordered a new MSD harness from JEGS, cut off a section of the red battery cable.
I noticed the old cable was Aluminum. The new cable from JEGS is Copper.
Can I crimped these 2 different metals together without any issues?
thanks in advance for any advice,
Jim
Ray
FWIW you can get the cover off an MSD box by drilling out the open-hole rivets that attach the cover to the heat sink/housing. The cables run through a grommet stuffed into the side of the housing. The grommet can be popped out easily enough but it's a PITA to get back in.
I think you are probably right, at the end of the cable it is shiny silver (looks like Al). It's probably the tin. The spot that is defective, it looks copper (plus a lot of copper oxide blue).
Jim
