Recommendation(s) sought for lubricant for my 64 Coupe's steering box.
Chassis grease. The last GM Part Number I have is # 12377985. About $15 a tube. But I believe GM is discontinuing this product. So pick a different manufacturer is you cannot get.
If box was rebuilt and synthetic was used, then add synthetic from then on. But most of these boxes just have the old dino stuff in them.
You can buy or make an adapter to connect grease gun to steering box fill connection. Paragon probably still sells them. Make sure to also vent box when filling thru second hole.
Larry
As I recall, Gary, the guy on this forum that rebuilds a bunch of these and has written articles on rebuilding steering boxes uses Lucas Green (if I recall correctly).
Due to the Corvette's engine setback the steering gear is very close to the exhaust manifold. For this reason it's subject to a lot of radiant heat that can dry out conventional grease. GM used to offer a special grease for C2/3 steering gears in a ten oz. tube, but it's long discontinued.
Use a full synthetic NGLI #2 grease like Mobil 1. If you are assembling from a complete disassembly and inspection, liberally apply grease as you assemble the ball nut/worm shaft and sector gear/shaft, then pack it near full leaving a small air gap.
Thanks to all for the information.
Will opt for # 2 synthetic.
Chassis Lube:
1. Is there a way to determine which type grease was used, synthetic or regular?
2. If not, can I merely force out the old grease with an application of #2 synthetic?
Thanks again, and Happy Fathers' Day to all Fathers.
Chassis Lube:
Mixing synthetic grease with non-synthetic grease poses a similar problem as mixing organic and non organic milk in your oatmeal. Watch out.
Chassis Lube:
No............the old grease (or what is left of it) is retained in the box. The new grease may or may not get to where it is needed initially.
If the box has never been properly serviced or greased and the expectation is to see a recovery of performance then you need to find grease from a genie in a bottle. This is almost as positive as using a rear bearing grease tool.
If the grease within the box is 10+ years old the best way to approach this is to remove the box, remove the cover, remove whatever is in there from grease to sludge, check the gears for pitting,clean up inside, use new grease- I use Lucas HD green now, install the cover with new gasket, set the lash. This is more involved then pumping in new grease but if that makes anyone feel better go for it as it will make you feel better more then actually doing much for the box. If going as far as outlined then you are better served to rebuild the box since you're almost there disassembling it.
I inspected the steering box more closely.
It appears it has never been serviced.
Although steering is good, I have decided I will pull the steering box, rebuild it, and add the appropriate grease.
Sadly, I never thought to do this all the years I have owned the car.
You will need a 0-30 in/lb dial TW to get it set correctly, a beam wrench is not accurate enough and sure don't go by the old fish scale method, that will not help you. If you have questions along the way let me know and I can coach you. Don't be surprised if the gears are bad.
