[C2] Off line stumble
She looks pretty enough, now I just need to fix this one final issue. Thanx.
Thanks to all in advance.
Dan
http://www.thecarburetorshop.com/Troubleshooting.htm
Might not solve your issue, but a stumble after the changes you say you made doesn't make sense, something else is amiss.
But that adjustment shouldn't normally change over time so it the carb wasn't apart it wouldn't seem the adjustment should have changed.
Do you know your total static and centrifugal timing? If it's under 36 deg then you can try increasing it a couple of degrees and see if that helps. But even at 10 deg it should not bog and more timing would just mask the real problem.
Checking the float levels is a good idea too.
It's a classic symptom of accelerator pump adjustment, make sure a small throttle movement there is some liquid fuel from the pump squirters. Double check the pump cam is in the #1 position on the throttle arm and adjusted where there is no gap at the pump lever at idle position, loosen the spring adjustment so it's slightly preloading the lever, don't worry about the .015 WOT adjustment.
Is the b-26 a new control, you are very detail oriented but make sure to check the vacuum hoses and timing, dwell etc just so you don't miss the simple stuff.
Get some carburetor cleaner and carefully spray the air bleeds in the air horn. If the engine will tolerate it, open the side screws another 1/2 turn each and see if it's any better. The throttle blade adjustment may not be correct and maybe not enough transfer slot on primary and to much air in secondary.
Your problem could be either lean or rich, but if there's no stumble after a couple of throttle blips, it's probably rich, and the first suspect is too high float level.
Remove the air cleaner, do a cold start and shut off after about 30 seconds. Then quickly use a strong flashlight to look down the venturis for fuel oozing out of any of the four discharge nozzles. If so the fuel level in the bowl is too high and needs to be lowered. There should be zero fuel flowing through the venturi discharge nozzles at idle, and after the engine is shut off, fully warmed up. Also do this test after engine shutoff with the engine partially warmed up - at least to the point where the fast idle is totally disengaged.
One of my driveability tests is to ease out the clutch very slowly from a dead stop without adding any throttle. The more overlap the cam has the tougher to do, but most should slowly accelerate to idle speed with full clutch engagement without a bad stumble, but it also depends on clutch engagement behavior. It can be difficult if the clutch is "grabby". The last one I did was a totally OE configured L-71 (still has the OE ported vacuum advance), and it passed this test with flying colors from 900 idle speed.
Ported vacuum advance may pass this test more easily than full time. As you ease out the clutch, speed and vacuum go down which looses vacuum advance, and may cause a stumble. With ported vacuum advance, total advance doesn't change as long as the centrifugal doesn't start until above idle speed.
On a normal "start" from a dead stop around town a L-79 should be able to achieve a smooth start to full clutch engagement without exceeding 1000-1200 revs.
Duke
Duke
To Duke's point if it is a high float level to the point where fuel is starting to drip from the booster nozzles in the venturi's you should be able to put your finger over the primary vent tube and look for fuel to drip from the venturi. If your front bowl has that vapor vent you will need to seal that also so pressure from the bowl cavity will push fuel out the booster nozzle. If no fuel is obvious I think the float level is probably ok.
Try the side screws another 1/2 turn out on each side as this will allow more fuel into the engine at idle and see if it's any better.
Why now and not before? The new valve job and camshaft replacement could require a slightly richer mixture, when you motor away from a stop and open the throttle blades the vacuum drops and the fuel falls out of suspension inside the intake manifold. The pump shot covers up the time needed for the related circuits to catch up and feed fuel to satisfy the engine.
It does not take long to replace the shooter nozzle but be very careful working over the manifold so nothing falls into the engine, it may be best to remove the carburetor.
That was the first thing I did about a week ago...should have mentioned that earlier. I ran that propane everywhere, intake to head, china walls, carb to intake, all around every vacuum hose, and just about everywhere else. No increase in RPM at all. I appreciate the thought.
Just got back from a 40 mile drive. Plenty of stop signs, didn't catch too many red lights...seems to run pretty good with the A/F screws turned out another half turn (now 1 1/2 turns out). The lone red light that I had to spend more than 30 seconds at was at the entrance to my development...she wanted to stumble a bit, so out of an abundance of caution (not wanting to get rear ended), I stabbed the clutch, blipped the throttle, released the clutch and drove her home. The weather here is in the 90's with 66% humidity, so working for any amount of time on her is taxing, to say the least.
