[C2] Brake Bleeding
Old Jun 29, 2019 | 03:49 PM
58n65's Avatar
58n65
Default Brake Bleeding
I upgraded my 65 to power brakes using 67 PB parts from Zip, I think. Anyways, everything is brand new from MC to lines to calipers. I've been trying to bleed the brakes using the clear hose and bottle method but I'm not getting anywhere. I started with the passenger rear caliper and see bubbles coming out but the fluid in the MC is still at the same level. I've pumped on them for at least 30 minutes and nothing seems to be happening. Shouldn't I see the fluid lowering in the MC if it was moving down the lines, in know a stupid question? Is there something I should have done before bleeding the calipers?
Thanks for any assistance,
Dex.
Old Jun 29, 2019 | 04:08 PM
Powershift's Avatar
Powershift
Dex:
Did you install the 1967 brake failure light block like all 67 cars have, or did you do something different??
I would start at the master cylinder with a helper and try the bleeder connectionss on the master cylinder. A correct 67 MC should have them. But if not, I would start at the closest connection to the master cylinder and see if you can get fluid to come out. Then work your way toward the rear. Same with the front system. Start closest to MC and then work toward the farthest point.
Did you bench bleed the MC?? That might be a problem, but if MC has bleeders, using them is just about the same thing.
I will often pull a vacuum on the caliper bleed connections to help get fluid flow started. I use a Mighty-Vac. But that should not be required for the job.
Larry
Old Jun 29, 2019 | 04:20 PM
58n65's Avatar
58n65
Originally Posted by Powershift
Dex:
Larry
Larry,
I did buy the block for the 67 setup. I didn't bench bleed the MC but will see if I can do it on the car.... When I figure it out. There's actually 2 borders on the MC and I'm trying the first house and bottle method now. I see plenty of air bubbling in the bottle but nothing coming out of the bleeder into the clear hose.
Thanks,
Dex.
Old Jun 29, 2019 | 04:31 PM
58n65's Avatar
58n65
Old Jun 29, 2019 | 06:33 PM
Powershift's Avatar
Powershift
Dex:
Inside the differential pressure warning light block is a piston with o-ring seals on both ends (I believe). Piston can move in response to pressure on either side. It may be pushed over to one side and partially blocking that brake line (front or rear). It should eventually self-center when front and rear brakes finally build pressure. That is why I said to break a few connections close to MC and see if you can get flow.
Also make sure you have a little bit of free play in the MC push rods...........between brake pedal and booster and between booster and MC. The AIM gives the free play, which is around 1/16 to 1/8 inch. You must have some free play for things to work correctly inside the MC.
Larry
Old Jun 29, 2019 | 06:49 PM
babbah's Avatar
babbah
Get a mity vac hand vacuum pump and from each caliper, furthest one first, put clear plastic tubing from vac pump to the bleeder end. Pump the vac then crack open the bleeder m, and close the bleeder. This works without pumping the brake pedal. Watch the mc fluid level and replace the fluid as required.
This should do it for ya
I've been doing mine this way for decades.
Old Jun 29, 2019 | 06:50 PM
babbah's Avatar
babbah
PS - never have had to mess with the pressure switch as well. Never have touched it in 52 years!
Old Jun 29, 2019 | 11:18 PM
58n65's Avatar
58n65
Dex:
Larry
Thanks Larry!!! I will give it another try later this week when I get more free time. I'll look at the AIM to see what you're talking about. This is my first time ever doing a full brake job. I've bled several brakes, after new pads or shoes, but this is the first dry system I've done.
Thanks,
Dex.
Old Jun 29, 2019 | 11:28 PM
58n65's Avatar
58n65
Thank you for the tip! Since this will be my only, hopefully, time doing this I might check into borrowing one from one of my mechanic friends.
Thanks,
Dex.
Old Jun 30, 2019 | 07:16 AM
alexandervdr's Avatar
alexandervdr
I am not the absolute expert on this, but have done several bleed exercises on my 64. In any of them , step 1 was bleeding the MC. If you have not done this, that is what I would recommend to start with. Using the bleed nipples as shown in post#4 it's a straightforward process.
Old Jun 30, 2019 | 09:32 AM
reno stallion's Avatar
reno stallion
C2 of Year Finalist (appearance mods) 2019
Buy some speed bleeders from summit racing that will also help
Old Jun 30, 2019 | 10:35 AM
58n65's Avatar
58n65
Thank you! I plan to bleed the MC as soon as I get more time....going to be a really busy week!
Thanks,
Dex.
58n65's Avatar
58n65
Thanks Reno for the suggestion!
Old Jul 3, 2019 | 11:41 AM
JohnZ's Avatar
JohnZ
NOTHING bleeds Corvette disc brakes faster or as thoroughly as a Motive Products power bleeder - takes longer to remove the rear wheels than it does to actually bleed the system.
Old Jul 4, 2019 | 09:38 AM
58n65's Avatar
58n65
Thanks John! If I keep having problems I might look into this.
Thanks,
Dex.
Old Jul 4, 2019 | 04:45 PM
Factoid's Avatar
Factoid
I have one similar, but instead of a hand pump, it clips to a tire valve stem and has a regulator you adjust to about 15 psi. Works great and you don’t need to bleed the mc first as it simply powers right through.
Old Jul 4, 2019 | 09:12 PM
JFP58's Avatar
JFP58
Did you leave the rubber boot on the new master cylinder? it needs to be removed if you have a brake booster for power brakes. If left on it will jam up between the master and booster, limiting the movement of the pushrod. Ask me how I know this..
To Brake Bleeding
