Does anyone know-
Old Nov 8, 2002 | 10:49 AM
coop_rod's Avatar
coop_rod
Default Does anyone know-
I have a 67 327 with munci 4 speed and 355 posi. When you accelerate through the gears it pushes the car left. Would a stabilizer bar on the back help this problem? The whole car has had a frame off.
Old Nov 8, 2002 | 02:30 PM
JohnZ's Avatar
JohnZ
Default Re: Does anyone know- (coop_rod)
This is a classic symptom of rear toe-in not having been properly set; side-to-side differences in rear toe-in cause precisely what you describe. Take it to a good alignment shop that KNOWS Corvettes and have a 4-wheel alignment done. It's particularly important to have the rear toe split so it's EXACTLY the same on both sides relative to the car's thrust centerline or it won't go straight when you get on it, and it will handle differently turning left vs. right.
