[C2] Rear Main Cap ?
Old Jul 20, 2019 | 11:43 AM
3154tm's Avatar
3154tm
Default Rear Main Cap ?
hi all, sbc newbie here and i'm doing the rear main seal shuffle in a '67. before i pulled the rear main cap i noticed a small dowel pin driven in between it and the pan rail. is this to control rear main bearing thrust and do i need to take any special precautions before pulling the cap? thanks.
Old Jul 20, 2019 | 11:51 AM
PAmotorman's Avatar
PAmotorman
that pin locates the cap
Old Jul 20, 2019 | 04:14 PM
3154tm's Avatar
3154tm
does the pin need to be driven out and then driven back in when the cap is reinstalled?
Old Jul 20, 2019 | 08:03 PM
Kerrmudgeon's Avatar
Kerrmudgeon
C1 of Year Finalist (appearance mods) 2019
no, it stays in place during any refurbish.
Old Jul 20, 2019 | 08:05 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
NO! don't touch it. Just replace your seal. Since you have the pan off, check the pan rails and make sure all the bolt holes are flush and not dimpled. Search on line about this for extra details. Dennis
Old Jul 20, 2019 | 10:16 PM
3154tm's Avatar
3154tm
thanks guys, i'm new to sb chevys so i've been researching the heck out of it. but now i'm suffering major mission creep. with the pan down i can see the front cover is leaking at the seal and the gasket. so now i've got to pull that. of course with the cover off it'd be foolish not to replace the gears and chain. also, i have an L79 intake i need to install eventually so might's well do the cam and lifters then. so now i'm considering a 2 piece TC cover so i don't have to go through the gasket hassle again. and so it goes.
Old Jul 20, 2019 | 10:46 PM
Bluestripe67
Exactly what engine do you have? Good idea to replace the timing chain and gears, but do you have the proper tools to pull the balancer? I would bother with a two piece cover. If you do the FelPro gaskets correctly, and you don't over tighten any of the bolts, you shouldn't have leaks. Why do you feel the need to replace the cam and lifters? If you don't have the book Rebuilding The Small Block by David Visard, I suggest you get it. Dennis
Old Jul 21, 2019 | 01:33 PM
3154tm's Avatar
3154tm
dennis, appreciate the input. the the car is a '67, the motor is '68 block that the PO said was a replacement under warranty. don't know if it was a short or long block or an empty case or how much of the original engine was swapped over. it doesn't look like it's been apart since then. so 50 plus year old internals.
Old Jul 21, 2019 | 01:54 PM
PAmotorman's Avatar
PAmotorman
GM did not use that locating pin on the BBC and if you do not do the correct procedure to locate the BBC rear cap you could have a rear bearing thrust surface problem.
Old Jul 21, 2019 | 04:13 PM
Tom454's Avatar
Tom454
If you decide to go with a 2 pc timing cover make sure it will fit behind the water pump without interference before you buy it.
To Rear Main Cap ?
