[C2] L-79
Old Jul 28, 2019 | 06:06 AM
C.F.P.'s Avatar
C.F.P.
Default L-79
L-79 aluminum manifold torque rate and bolt sealant?
Thanks....
Old Jul 28, 2019 | 06:25 AM
856666's Avatar
856666
30 ftlbs and use a non-hardening sealer on the threads
There should be a small flat washer under the head of the bolt on the aluminum intake
I like to tighten from the center out - side to side and then recheck at the end and after running the engine.
https://www.jegs.com/tech-articles/s...ine-specs.html
Phil
