[C1] Stops running after acceleration
Old Aug 2, 2019 | 08:16 AM
57OHVette's Avatar
57OHVette
6th Gear
Default Stops running after acceleration
My 1957 corvette starts right up and will run at idle with no problem. After driving a short distance when you go to give it gas it starts sputtering loses power then shuts off. Will start back up but only runs for a couple seconds and stalls out again. I changed the ignition coil but had same problem. Any thoughts on what to try next?
Old Aug 2, 2019 | 08:22 AM
Steve59's Avatar
Steve59
sounds like a gas-carb-fuel filter problem
Old Aug 2, 2019 | 11:31 AM
vettsplit 63's Avatar
vettsplit 63
From: "You may all go to Hell- and I will go to Texas- Davy Crockett
St. Jude Donor '12
I agree. Either your float levels are way low, or your fuel pump is not delivering . Need a little more info.
Old Aug 3, 2019 | 04:42 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
First check is to make sure your fuel pump pressure and volume is sufficient - this document describes the two tests using a common vacuum gauge:
File Type: pdf
To Stops running after acceleration
