[C1] Ground strap orientation
Old Aug 10, 2019 | 03:19 PM
VETT457's Avatar
VETT457
Default Ground strap orientation
'57 270 passenger side front mount - what's the correct orientation/location for the ground strap?
Old Aug 12, 2019 | 09:43 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Here you go, this is out of the 57 AIM.
Old Aug 12, 2019 | 03:08 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
I believe most late model C-1's are similar.. 61 shown
Old Aug 14, 2019 | 04:47 PM
JohnZ's Avatar
JohnZ
Shouldn't be any orange paint on the nut, washer, or the ground strap - only on the motormount bracket.
Old Aug 14, 2019 | 05:04 PM
dcamick's Avatar
dcamick
Thanks John!......You must understand, I am on the Dark Side of the Hobby!!! Because it was you that pointed that out.....I'm going to fix that!!
Old Aug 14, 2019 | 06:03 PM
VETT457's Avatar
VETT457
Unfortunately I don't have a good image of this which is what prompted my post. My car is very original and all three of those items have paint on them.
Old Aug 14, 2019 | 06:57 PM
0Willcox Corvette
Former Vendor
Paint or no paint, my picture is from the original not the mutl copied assembly manual.... It's my belief that the bracket (as your bracket shows) was painted with the engine before installation. However, the bolts, nuts and washers were installed later after the engine was installed and would not have any paint on the other parts. You should consult with the 56-57 NCRS team leader and they should be able to point you in the right direction or purchase from NCRS the judging guide for your car....
Willcox
Old Aug 15, 2019 | 09:10 AM
VETT457's Avatar
VETT457
https://www.corvetteforum.com/forums...t-my-nuts.html
Post #6
To Ground strap orientation
