Horn button removal
Old Nov 11, 2002 | 08:55 AM
WikdC5's Avatar
WikdC5
Default Horn button removal
My friend has a 61 and needs some instructions on how to remove the horn button. If you can help please do...thanks.
Old Nov 11, 2002 | 09:20 AM
62fuelie's Avatar
62fuelie
Default Re: Horn button removal (WikdC5)
Just pull it off. If you don't want the horn to blow while you do it, disconnect the battery. If it's rusted in place a screwdriver might be necessary, but I've never seen one I couldn't pull off by hand.
Old Nov 13, 2002 | 12:31 AM
clcintx's Avatar
clcintx
Default Re: Horn button removal (62fuelie)
My horn doesn't work on my '61 - and I don't have time to wait for my dad's next visit from Kansas to look at it (I need to pass a Tx state inspection) - Any suggestions on what to check before I take it to the shop??
Old Nov 13, 2002 | 08:05 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Horn button removal (clcintx)
Could be a LOT of things. First, the horns themselves. You could test them each independently. Then, it could be the horn relay. OR.......it could be the button....and mechanism under the button, and finally the wiring between any of these. The little plunger gizmo under the horn button can break, or wear out. I would first check the wiring coming out of the steering column, and check the spade connectors where they hook into the main harness. Then, I'd check each horn....put 12V positive directly to the lug, leaving the body of the horn grounded to 12V negative. See if they blow directly. Push the horn button and see if the relay "clicks". If it does, you know you're getting power that far. Hope this helps. Chuck
Old Nov 13, 2002 | 09:44 AM
StrayDog's Avatar
StrayDog
Veteran: Marine Corps
Just gently pry off.....the horn button on my 1966 big/block flys off :eek: into my lap when running the 1/4 mile........... :seeya
Old Nov 15, 2002 | 07:50 AM
WikdC5's Avatar
WikdC5
Default Re: Horn button removal (StrayDog)
Thank you guy's for the info.
To Horn button removal
