Question, does the C2 coupes use the same bird cage?
Also does anyone know where to purchase a whole Bird cage or replacement sections?
Thanks.
I believe there is a source for a complete C2 Coupe Birdcage now. Check the link below, or 99% of it. That one 1% may be the two top corner die formed pieces that tie the windshield and top braces together.
Note: There is a company that made most all the fromed pieces, except the lower front door hinge assembly the company in the above thread makes. If nothing else he should be able to point you in the right direction to get what you need. I believe most of the Corvette Vendors sell those pieces made by that supplier, well as the part(s) supplier .
