3367 accelerator pump cam
Old Sep 2, 2019 | 08:08 PM
Boiler_81's Avatar
Boiler_81
Default 3367 accelerator pump cam
I'm rebuilding my 1966 327/350 HP carb. The accelerator pump cam needs to be replaced. The once currently on the carb is either faded red or pink. Chicago Corvette shows the 3367 uses a white cam. Which is correct?
Edit: I just looked again. The CC site exploded diagram leads to the white cam. However, searching for accelerator pump cam on the site brings up both the red and white. Red is listed for 3367.
Old Sep 2, 2019 | 08:45 PM
tbarb's Avatar
tbarb
It's my belief that the #218 white cam is correct for the 66-67 Holley's. If you find the graph that shows lift and throttle angle the red and white cams are very close.
Let's see what others say.
