developed a cooling issue . I checked the easy stuff (timing, sender accuracy), and did a coolant flush, changed the thermostat and 13# cap but it did not resolve.. The car has always run (9000 mi) in the 180*, it gets up to temp as usual and then it spikes up to 250*
When it is heating up I can see on the gauge open and go back down when it takes the cooler water from the rad It stays at 108* for a few miles than spikes to hot!
The rad went thru a few cycles so I believe the air bubbles were out of the pockets as I added a bit of water each time it cooled down. The engine is a crate ZZ4 with everything and a new copper/brass rad except for a short water pump (9000mi). I have checked with an IRgun and it agrees with the temp gauge....hot! The engine and rad were clean when the flush was taking place
This began out of the blue? Before you changed anything at all?
Warm the engine up with the radiator cap off, turn the engine off, then pressure test the system. Pump it up to 20#. The needle shouldn't even budge for 30 minutes,
Is there a carbon monoxide test that I can perform at the rad ?
I have heard of a "kit" as I don't think I can drive it to a rad repair shop 12 miles to the closest one
I've used this kit to check for Combustion Gases present in the Coolant/Radiator. Works well and was available at NAPA. Can't find the specific pic, no doubt because I had it stored on Photobucket but did find an old thread where I posted the pic. Hope this comes out. https://www.corvetteforum.com/forums...post1586934490
When you use this kit, it typically helps to lower the coolant level so there is no wet-splash up against the tester but if your car has an expansion tank, there should be ample distance between the bottom of the tester and the coolant.
If after a minute of squeezing the bulb, the blue liquid turns yellow, that's not good and indicates the presence of combustion gases and therefore a ruptured/blown head gasket or ???
Good luck,
Mike T - Prescott AZ
That would be enough for me right there but regardless of what the combustion test says, the fix is in the motor and not the external cooling system. I would do both gaskets and anything else worthwhile while the hood is up and you are dirty.
Dan
You make it sound "so easy"!
I am going to try and source a test kit...........just so I can procrastinate longer!
I don't mean to, and I'm not known as Mr. Sensitivity in my home. I have 8 old cars and have grown hardened to the various failures and constant need from one or the other of a repair. Its fleet management for me. Be thankful its on the top and not the bottom!
Good luck.
Well, sorry to say I've been there, done that! The ZZ4 has an iron block and aluminum heads, and experiences different expansion and contraction between the two. Mine came with a sandwich type head gasket which sheared over time from the effect of the different expansion and contraction between the heads and the block. I replaced mine with a solid gasket; no problems since.
Two pieces of advice -
First, replace both head gaskets even if only one is leaking - you do not want to do this again, and since the intake is already off you're most of the way towards the second one..
Secondly, be sure to use new rocker arm nuts when you put it back together. The originals are basically single use and some do not hold when reused. I learned that one the hard way.......
Upon further inspection and an after the 20# pressure test and 8 hose connections, I have found three AF leaks!
Today I am going to address the hose connections and try using 15# of pressure and look for more AF leaks
I sure hope I did not compromise the heater core!
Slow down and verify. They'll have you changing the rear end. The pressure loss could come from anywhere in the cooling system. Are you losing water with no apparent leaks, i.e. water under the car or in the oil. I hope it's minor.
No A F on the floor or in the oil
I think I have addressed the hose leaks and it will hold 15# for 30+ min
Today I removed the thermostat to see if I could keep it at operating temp with ram air but same results
it stayed in the -180* for a short time then started climbing to 250*
Time to remove the rad and have it serviced, I have procrastinated long enough!
