[C1] 548 block stamp pad
Old Sep 7, 2019 | 03:09 PM
Mailbu Beach's Avatar
Mailbu Beach
Default 548 block stamp pad
What is an L suffix
strange block has an F107 casting date ...548 block
Old Sep 7, 2019 | 03:33 PM
tuxnharley's Avatar
tuxnharley
56 or 57 265 ci, 2 bbl manual transmission in a truck.
Old Sep 7, 2019 | 03:34 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Suffix
An "L" suffix decodes to an engine from a 1956-57 265, 2 barrel, manual trans, HD truck. 30, 40 & 80 series.
RON
Old Sep 7, 2019 | 05:03 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
It's got to be a '57 engine since the block is a 548 casting.
Old Sep 7, 2019 | 08:35 PM
Mailbu Beach
A June 9th engine stamp and a June 10th casting date?
Old Sep 7, 2019 | 09:06 PM
Mailbu Beach
RON
Old Sep 7, 2019 | 09:08 PM
Mailbu Beach
I wonder if the truck motors were heavy duty in an any way
Old Sep 7, 2019 | 09:48 PM
jim lockwood
Not quite. The block was cast on June 10, 1957, but it was assembled July 9. The "F" in the assembly stamping denotes "Flint", not June.
Old Sep 7, 2019 | 09:50 PM
jim lockwood
I doubt it. If they had intended to make a heavy duty casting, it would almost certainly have been given a different casting number. It's possible, however, that 548 truck engines were built with better bearings and maybe other HD internal parts. That's speculation on my part, though.
The only oddity about 548 blocks is that they were used to build both 265s, with a 3.75 bore and 283s with a 3.875 bore.
Jim
Old Sep 8, 2019 | 12:22 AM
rongold's Avatar
rongold
That makes more sense.
Old Sep 8, 2019 | 06:36 AM
Mailbu Beach
Right you are
Old Sep 8, 2019 | 06:38 AM
Mailbu Beach
Jim
Old Sep 8, 2019 | 02:14 PM
rongold's Avatar
rongold
Jim
Just wondering---Can any 548 block that was built as a 265 be bored out to make it a 283, or only select blocks ??? Most later blocks cannot withstand a .125 overbore without boring into the water jacket.
RON
Old Sep 8, 2019 | 03:28 PM
jim lockwood
RON
To the best of my knowledge any '548 block 265 can be re-bored to be a 283. I don't have first hand experience doing it, but I've never heard of anyone punching through to the water jacket. Best, I think, to have the block sonic tested before you start.
To 548 block stamp pad
