Help with engine vibration
Old Sep 10, 2019 | 08:51 PM
Grmvettes's Avatar
Grmvettes
Default Help with engine vibration
1965 327-350hp no power steering. Has idler on drivers side, alternator on passenger side. So I have a vibration in the engine, very noticeable around 2000 rpm’s. Even with the car not moving, in neutral, clutch in or out. I disconnected both belts and it went away. I replaced alternator belt only and the vibration returned. Any suggestions?
Old Sep 10, 2019 | 09:01 PM
Avispa's Avatar
Avispa
Possible warped water pump pulley or fan has a bent blade or two. Never heard of an alternator getting out of balance but suppose it's possible
Old Sep 10, 2019 | 09:03 PM
pop23235's Avatar
pop23235
The Take the alt. belt off and install the idler belt.
Still vibrates, change the water pump.
No vibration, change the alternator.
Not resolved, remove fan.
Old Sep 11, 2019 | 07:56 AM
6T7L71CPE's Avatar
6T7L71CPE
I had a similar vibration and it was caused by an out of round pulley on a replacement alternator.
Old Sep 11, 2019 | 03:34 PM
Grmvettes's Avatar
Grmvettes
Removed clutch fan and the issue seems to be resolved. Clutch fan looks great. I guess it could still be the issue.
Old Sep 11, 2019 | 04:10 PM
856666's Avatar
856666
Manual Trans?
If auto trans conversion unbolt the torque converter
Phil
To Help with engine vibration
