[C2] Another numbers question...
Old Sep 17, 2019 | 08:17 PM
ratvet's Avatar
ratvet
Default Another numbers question...
I have finally decided to do something with my 65...(sitting since 1988)...can you guys help with engine numbers please? I've checked my Noland Adams & black book but can't find anything. 18N375395...and VOIIOME. Thank you in advance. (
​​​​​​​John from Boston)
Old Sep 17, 2019 | 08:26 PM
65GGvert's Avatar
65GGvert
67 or 68 Camaro 327 210 hp, 2bbl powerglide according to the Lime Book up in the Stickys at the head of this forum.
Old Sep 17, 2019 | 08:37 PM
ratvet's Avatar
ratvet
Thank you very much...and I will check that lime book too...
Old Sep 17, 2019 | 08:39 PM
Ron-C2's Avatar
Ron-C2
I am not an expert on engine codes, but after doing some google searches this is what I came up with:
"18N375395"
"1" = Chevy
"8" = last digit of the year of car, could be 68, 78, 88, etc. (Probably 1968 given the other data).
"N" = car assembled in Norwood.
"375395" = the last 6 digits of the car's VIN (the car the engine originally went into).
"VOIIOME"
"V" = engine made in Flint, Michigan.
"0110" = engine made on January 10th.
"ME" = engine is for a 1967 Camaro, 327, Powerglide transmission, 2 barrel carb, 210 hp.
My guess is your engine came out of a 1968 Camaro whose engine was built in January 1967.
The web pages where I got I the info:
http://nastyz28.com/chevy-engine-code-stampings.php
http://nastyz28.com/gm-chevy-codes/c...s-suffix-6.php
Edit: I see 65GGvert was much faster in giving the same answer.
Old Sep 17, 2019 | 08:43 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
Your '65 has a '66-'67 grill on it, but you probably knew that already.
Old Sep 17, 2019 | 09:40 PM
ratvet's Avatar
ratvet
Thank you Ronjin & Easy Rhino...actually did not know about the grill....
To Another numbers question...
