Power steering C1
Power steering C1
Hello
Has anyone recently installed an ELECTRIC power steering kit on a C1 ?
Which kits are recommended ? Possible to install in my garage or would I need a professional to do the job ?
Thanks !
Thanks !
An actual install of an aftermarket kit:
What happens if the electric servo motor fails? Is there no steering at all, or is there some sort of over ride clutch that allows normal manual steering?
Doug
Doug
Good question.....a forum sponsor, Silver Sport, offers the conversion. Anybody considering it should call them and get some straight answers:
https://shiftsst.com/store/electric-...-corvette.html
Pro Mechanic
Received 1,335 Likes
2023 C1 of the Year Finalist - Modified
It feels like standard (non-powered) steering. Just like any other vehicle with hydraulic power steering with the engine turned off. The motor is attached to a very high pitch worm gear. With no power you're just twirling the motor with the "driven" gear.
I would assume this would be the same? more effort to steer if a failure, but still steerable?
As far as this being do it your self project, you will need access to a mill to put flats on the shaft, and good power saw to make straight cuts, or know someone that can do that part for you, either paid, or free. Having a lathe to clean up the cut tube ends, woudl be a plus
Doug
Pro Mechanic
FWIW, non powered power steering on a normal hydraulic feels a LOT harder than the normal manual steering option, you KNOW when the PS pump isn't working.
Doug
Doug
Pro Mechanic
We have these guys in Europe: https://www.youtube.com/watch?v=NivxqlpVRMA
They provide drilling guide to avoid using a mill...
They claim in case of failure it just gets back to usual feeling...
I have the American Powertrain: https://americanpowertrain.com/shop/...r-c1-corvette/
I had it installed by a good friend who owns a shop. He was very impressed with the ease of installation. If the elect motor fails you still have the same direct mechanical connection as original. The motor sits up under the dash and has a **** that can adjust boost. It has made the car easier to maneuver and more fun. The system is progressive as well so you do not have over boosted steering at highway speeds.
Under hood still remains original and you cannot tell the system is on the car. LOVE IT! and it was worth every penny.
Pro Mechanic
For $2750.00, I will eat more Wheaties first. I never noticed any issue with steering, except maybe stopped, on really rough surfaces--that takes a bit more effort. Once moving, no issues at all.
Doug
Doug
Received 3,790 Likes
2015 C1 of the Year Finalist
I realize that some (or many) people feel they would get more enjoyment from driving their 53-62 Corvette (remember, I STILL do not do the C-crap) if their car had power steering, power brakes, air cond, ultra hi-tech stereo system, etc, etc, etc.
I'm 76yrs old, and the added features that I've done over the years to the 56 is a small block with more power, home made HD brakes and upgraded the chassis/susp to 60-62 specs.
I feel strongly that if the front suspension and steering is properly rebuilt, a good alignment is done and radial tires (NOT big fat tires on extra wide wheels) inflated to 32-34psi, then the car will drive just fine. On 53-56 models, it would be good to add the cross member-to-frame shims that were installed on late-56/62 cars.
I do not hesitate to admit that when stopped, or moving VERY slowly, the stock steering is somewhat stiff. But again, I'm 76 and I do just fine when driving the 56-----------------actually, it's probably good exercise for this aged body!
Oh ya, and my daily driver (and has been since 1962) is STILL a 51 Chevy 4dr (which is bigger and heavier than the 56), and it has bone stock steering, suspension and drum brakes (which is the same as the 53-62 Corvettes). I will admit that the front tires are 225/75X14 radials, which helps a little when stopped.
WhiteC1 (09-20-2019)
Received 6,738 Likes
C2 of Year Finalist (track prepared) 2019
C1 &C2 Fan
Sorry if I am momentarily hijacking this thread...
DZAUTO - Above you wrote “...On 53-56 models, it would be good to add the cross member-to-frame shims that were installed on late-56/62 cars...”
I have seen those on the later years. What is the benefit/result of adding those two shim plates? What might be the drawbacks? I am working on the chassis of my 54 now.
The disadvantage is a slight increase in steering effort, most noticeable at low speeds.
My '54 does not have them and steering is very light, almost two-finger easy. My '60 has them and the greater steering effort is obvious.
Jim
The advantage of the shims is an increase in positive caster which improves the return-to-center action of the steering.
Jim
Jim
