[C2] 63 alternator bracket
You would also be smart to get the VAK-6365 Lectric Limited wiring harness designed for moving the alternator to the LH side without messing with the horn relay or voltage regulator...
I assume you have an upgraded alternator ? If not, the stock 628 alternator can be internally upgraded to 70-100 amps.
Most of the A/C 63 specific parts are for 250hp-300hp engines, if you have something else you should confirm all of this information...
You clearly don't have my article on tips to install Vintage Air A/C in a '63 so here it is...
Thanks Frankie
Bill
