Timing issues
Before pulling the dist. set the balancer notch at 8-10 on the timing tab, number one nearly at TDC of the compression stroke. Note the indexing of the rotor tip as it clears the gear (it will rotate CCW). It should be along engine centerline. To reinstall start with the rotor tip pointing approximately along engine centerline and drop in. The rotor tip will rotate about 20 deg. CW as the gear ingages.
If it won't seat all the way, you'll have to remove the dist. and tweak the oil pump drive slot. A paint mixing stick is a good tool to use.
Once seated connect an ohmmeter to the coil negative terminal and a convenient ground. Rotate the dist. until you get continuity. This is called "static timing" the engine, and it should be near 8-10.
In the final position at 8-10 initial the plane of the cap window should be approximately normal to engine centerline and the VAC should be about halfway between the coil bracket and manifold interference points. If not, there's something wrong with the installation or the cam gear is not properly indexed to the cam. This has been observed with some aftermarket cams and the dimple in the dist. gear must be indexed 180 deg. out from the rotor tip.
Start the engine and check with a timing light and tie down the dist.
Duke
