looking to replace some rivets on the car , is there one brand or type of rivet tool that is better than another
thank you in advance for any info
regards Bob
Bob, depends on where and what type rivet. I purchased a real rivet gun as I’ve removed and replaced a lot of them. The shanks are whatever shape you need. Mostly a flat head for the big flat heads and a convex head for the button headed. There are others needed. I still have not obtained ones for the tube rivets.
Years ago I purchased a used CP 3X gun and various accessories. Ebay is one source, but there are a number of places that sell reconditioned rivet guns from aerospace industries. Price around $150-200.
Buy a good one and it should last two lifetimes. I generally use about 50 psig pressure for driving the rivets.
I have a heavy duty manual rivet gun that will never die. In fact, your hand will die before it does.
A couple years ago, I was installing a bulkhead delete kit in my 1988 LR Defender to achieve more legroom. It required installing about 15 3/16” steel rivets. I did one and bought an electric gun for about $150. God send. This after building two FFR Cobra Coupes each requiring about 500 rivets which I did by hand. Never again! A powered rivet gun is the only way to go.
regards Bob
If you already have this, disregard. When I replaced rivets a while back some folks referred me to this article "Riveting Experience" (attached). I used the "bucking bar" with air chisel (with indented punch) and it worked well for me.
Reason: change
Harbor freight gun Adjustable air for the pounding strength Cleco pins and a goo set of bucks Can't practice enough Some finished parts I fyou don't get it right take it out and do it again
When it comes time to remove the old rivets, I found the easiest and quickest way was to use a ball peen hammer and a 1/2" wood chisel. Place the chisel bevel side up and with a hard swift whack it will cut through the aluminum rivet like soft cheese. If you try and use a drill, the drill bit will want to walk. You may have to repeat this operation on the reinforcement bracket side. Use a 3/16 pin punch to remove the remaining tail. Zip sells the correct 9/16 size head rivets for mid-years, CC rivet heads are 1/2", can't say about any other vendors. You can use #10 screws, flat washers, and nuts to align, draw, and hold the bracket firmly against the body until the first couple of rivets are set. Someone else may have a better method but this way worked for me.
