Timing
Old Oct 19, 2019 | 01:11 PM
Dm9917's Avatar
Dm9917
6th Gear
Default Timing
So I have a L36 390hp 427 and was wondering if anyone knows how altitude changes the timing or if it does were about 6000 feet above sea level and I’ve set my initial timing at 12 degrees advanced seems to be running good at lower rpm but at higher rpm seems to not be.
Carb is rebuilt and jetted for altitude it likely needs more fine tuning adjustment but I have to think timing with altitude needs maybe to advance more ?
any thoughts ?
Old Oct 19, 2019 | 01:42 PM
Tampa Jerry's Avatar
Tampa Jerry
One of the gurus on timing on the forum is Lars. He lives in CO as well. Search for his papers on the forum. SWCDuke has also written a paper or two on the subject. There is a wealth of information right here. Jerry
Old Oct 19, 2019 | 04:17 PM
Donald #31176's Avatar
Donald #31176
My guess would be that you would need more lead due to the leaner air/ fuel mixture . The leaner the mix the more advance needed to burn .completely. 12* initial is pretty high for a big block.
Old Oct 19, 2019 | 04:59 PM
63 340HP's Avatar
63 340HP
The car needs more idle advance at altitude (and the test at 12 degrees confirms this), but it still need to limit the total advance to 36-38 degrees to avoid hitching and detonation at altitude. High altitude fuel is also blended to reduce vaporization compared to sea level fuel (much like Aviation fuel), a property that prevents vapor lock but also makes the fuel harder to ignite and burn clean with diluted air fuel mixtures. Lars distributor tuning papers can lead the way to a solution.
Old Oct 20, 2019 | 09:03 AM
SWCDuke's Avatar
SWCDuke
any thoughts ?
There was a recent thread on the subject that you should check out. Also, search for posts by me and read the tuning seminar pdf. 12 degrees may be a bit much given that the OE centrifugal is 30 @ 5000. Higher rev performance will improve with lighter centrifugal springs to get the full 30 in by 2500 to 3500 with detonation as the limiting factor.
Duke
To Timing
