Distributor issue before I begin
See the slot?
Loosen the bolt and slide the clamp back until it clears the housing.
Now, stuff a rag in the dizzy hole so you don't drop anything down it and reinstall the clamp and bolt, loosely, with the dizzy out, and the clamp retracted.
Put it up over the dizzy base once the dizzy is seated in the oil pump slot and tighten.
Doug
Doug
My 283 (61) TDC on the compression stroke was nearly pointing at the #1 cylinder (5 o'clock). Was that correct?
Thanks all!
Thanks all!
With the shaft out it should roll straight and clean on a piece of glass or polished granite (with the football hanging over the edge).
Here is a photo of a new shaft above a severely worn old shaft (for reference of where to look for wear):
Paul
"Look at the gear and you will see that the hole for the roll pin aligns with a tooth on one side but points between two teeth on the other side. Because there are an uneven number of teeth.
The rotor should point to the position on the gear that the roll pin is between two teeth. I always use this method as it's possible that the dimple on the gear is drilled on the wrong side."
Per our erudite forum member Critter1...
Thanks all!
So you need to understand that if the dampner mark has been verified to #1 TDC when it points to zero on the timing tab the #1 cylinder and #6 cylinder are both at TDC. And I explained previously how to see which is ready to fire by looking at the valves. But you need to understand that as the crank moves 90* the next set of pistons in the firing order come to TDC (cyl #8 and Cyl #5). But the distributor only moves 45* to the next terminal on the cap. Why/ Because the the crankshaft turns twice for every single rotation of the cam and distributor. So the rotor only turns 45* to reach the next terminal and you should realize by looking at the cap it will take the crankshaft 2 turns for the distributor rotor to turn only once. And as Frankie labeled the cap for you you can see which cylinders come to TDC together as they oppose each other on opposite sides of the cap. Really pretty simple once you sort it out.
But the issue is not just pointing to the correct terminal at TDC for that cylinder but how much initial advance you need which may not be reflected by where the rotor points. Because of phasing remember? So what I'm really saying is once the distributor is in and clocked where you want it you still have to find the initial advance you want to use or as some owners call the sweet spot for idle and they use just the engine sound to set their initial advance. Not saying which is best just you need to understand how it works and chose the method you like for yourself. But monkey see monkey do methods are really just going to make more problems for you as try to set your engine idle the way you like it. You may have to clock the distributor more than once, maybe more than 3 times. Who cares how may tries but you will find out what you can do with that advance can in the way and what you can't. Someone else's opinion is just that!
I used a piston stop to calculate TDC and its relation to the balancer/pointer when the rotor was pointing to what I thought at the time was #1, now turns out that it was #2 on the cap and that the dizzy is off a tooth or so. She ran fine by the way and with an initial of 16* BTDC after I had previously remapped the WOT advance curve. I still had about 3/16" clockwise rotation available before the VAC would contact the coil.
No, I did not pull the valve cover to study the valves. My reasoning was that if she was set up with an initial of 16* and if it was #6 piston actually in compression not #1, I would think she would run horribly if at all. The spark plugs would be firing on cylinders that are on their exhaust stroke. Other than the erratic idle, she ran nice and smooth through 5K rpm while driving so I would think that when the rotor points to a cap tower, it's corresponding cylinder is in compression. If I am wrong on this point please correct me.
My initial plan was to reinstall the dizzy in the same place using the rotor tip and dizzy body index marks I made after having rotated the crank to 8* (it was suggested) and viewing the rotor position. If I get it back in and all the index marks are aligned she should run. The assumption is that once rebuilt with all the excess end play shimmed out of her and reinstalled the way she was, she would again run fine, only with a better idle I would hope. Duke, and I assume others, feel the dizzy positional error should be corrected.
The car has been on my 4 post lift and has not moved so no movement of the crank since I started. So the balancer is still pointed at 8* BTDC. Nothing has moved. If I walk the dizzy clockwise so that is seats all the way with the pointer at the correct #1 cap tower and I rotate the housing back to my index line, the dizzy will be set up with an 8* initial timing and indexed properly to the cam with the rotor pointing the the correct #1. Obliviously I will reposition the spark plug wires before starting her.
If I am still missing a point here please do have patience and explain it to me, the simpler the better. That said I think my reasoning is correct here.
I
With the balancer notch on 8-10 BTC compression stroke #1, once the dist. base is seated rotate the dist CW to the limit then rotate CCW until the points JUST BEGIN to open. If you use an ohmmeter you will be within a degree of where the balancer notch is set, and if you just eyeball it you will be within a couple of degrees. The above is called static timing the engine. The VAC should end up about midway between the interference points, and the window near normal it engine CL. If not, you're off a tooth.
It might take a little experience, but with a little practice you will be an expert, like I became over 50 years ago when I had to learn on my own "the dimple deal" and how to properly remove and install a distributor and static time the engine. All the so-called "experts" I talked to back then as a 19-year old kid trying figure this out were clueless... I mean TOTALLY, UTTERLY CLUELESS!!! And that was the last time I ever talked to them about anything car related.
Other than having to tweak the oil pump drive shaft sometimes, it drops right in and the engine starts... every time.
Follow my instructions precisely from my earlier post and you will be successful, including the initial rotor tip position as you start to drop the distributor in.
Duke
Just finished disassembling everything and not much to report.
Upper and lower bushings look good, No visible scoring in them.
The mechanical advance bushing is still in place.
The felt washer and spring clip could be replaced and the grease within the well looked like the saw dust-oil mixture I have read about.
The VAC is a new B-26 unit so it's fine.
The breaker plate ground wire looks fine, still (soldered?) to the underside of the plate. The wire itself flexes easily, probably was replaced when the PO installed the SE ignition.
Tach cross shaft gear looks fine as does the mating teeth on the main shaft
The only question is the condition of the main shaft. It did not want to come out yesterday. As per advice I did clean a load of crap out of the housing where the cross shaft lives and then soaked it overnight in Blaster. Came right out today. The shaft is chrome but there are obvious areas of surface corrosion. Not pitted, just surface stuff. There are what looks like circumferential scratches at the usual spots where she spins in the bushings but when one runs a finger over them, your hard pressed to feel much. As advised I rolled the shaft on a flat steel surface and it rolls effortlessly and I can not appreciate any gaps so it appears to be straight and true.
So do I just polish up the surface corrosion with fine emery cloth, leave it as is or buy a new shaft?
Since you have it all apart you might looks at the bushing on the advance stop pin and see if a larger one could be installed that would clear the slot. That would decrease total centrifugal advance and allow you to increase your base timing a little which is usually a good idea for performance and driving ease. I've done this on several distributors - Mopar and recently my Vette. I've tried lots of times to mic the length of the slot, mic the diameter of the existing bushing, subtract it from the slot length. Divide that by the total number of degrees of centrifugal advance it currently is running, to come up with a measurement in thousands per degree of crank advance. And then figure how many thousands bigger bushing I need to limit the mech advance to what I want to change the total mechanical advance to. It never works out.
Instead playing with advance bushing size is strictly a trial and error process. I did find that MSD bushings will work on a Delco distributor, although most of them are too big to fit in the slot without flattening the sides to narrow it, or filing the width of the slot wider. And you can't go by the MSD literature as the MSD advance plate apparently has different geometry for the advance stop and slot. I found the next from smallest "sliver" MSD bushing worked best in my TI distributor and only took a very small amount of flattening of the sides to fit in the slot. But I ended up with 18 crank degrees mechanical advance when I was looking for 20. The next smaller bushing was barely larger than the one I put on the stop pin years ago that gave me 24 crank degrees advance so I stayed with the silver one and set 18 degrees base timing. If interested in doing this you might find a kit somewhere with various size bushings specific to Delco distributors but I haven't seen one.
May be useless information if you plan to stick with stock GM settings but since you are this far in I thought I would mention it.
All that said I need to draw a line somewhere. Refreshing the dizzy I have and shimming out the excessive end play, reinstalling it correctly, getting 36*-38* all in at 2,600-3,000, and a better idle quality (end play correction I'm hoping) should be good enough. Trial and error is one thing when experimenting with springs, and another if I have to remove and reinstall the distributor over and over. If I can accomplish the above stated goals and get it back in and she starts, I'll feel like a junior wrench turner.
Thanks.
