[C2] Bolt Identification
Old Nov 10, 2019 | 01:36 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Default Bolt Identification
Before I tell you where I took this bolt from. Is it a 63 Bolt? Or aftermarket "thingy"? There are no markings on the head
Old Nov 10, 2019 | 02:22 PM
TC233's Avatar
TC233
CF Senior Fox Bat
Bolt was in Lower Control Arm lower bushing where AIM says there is a pop rivet? So were their rivets in bushings all through 63 that anyone knows? Frankie?
Old Nov 10, 2019 | 02:46 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
the ball joints where NOT pop riveted. rather held on by a solid steel rivet I never seen a head like that
Old Nov 10, 2019 | 03:44 PM
rongold's Avatar
rongold
From: Putnam Valley, New York. Amateur Radio Operator K2NS
Default Bolt
That bolt was used to retain a replacement ball joint in the lower control arm of 63 & later Corvette & also 55 and later full sized Chevrolets. I don't remember if it went in the front or rear of the control arm, but the reason the bolt head is so thick is that on some cars the bolt head doubled as a steering stop.
RON
Old Nov 10, 2019 | 03:47 PM
TC233's Avatar
TC233
CF Senior Fox Bat
RON
Makes sense because I got them from the steering arm side of the ball joint on both lower ball joints, thanks. So the bolt must have come with the replacement ball joint
To Bolt Identification
