Paint Experts
Old Nov 21, 2002 | 08:12 PM
pittsaj's Avatar
pittsaj
Default Re: Paint Experts (Grey Ghost)
That might be a thought...
I wonder what powder might act as a drying agent :rolleyes:
It could soak up the fluid and tend to wick it away from the surface
What do you think??
Baking soda, corn starch, flour... something else
Any ideas on this?
[Modified by pittsaj, 5:13 PM 11/21/2002]
Old Nov 21, 2002 | 08:28 PM
rwd's Avatar
rwd
Default Re: Paint Experts (pittsaj)
Weird. I'd be very careful with heat, particularly since afaik the substance itself is unknown. Maybe kitty litter, oil dry, baking soda or something on that order might do something without potentially causing damage. Since the paint is original, personally, I'd be more concerned about collateral damage, although I'm sure it must be a very frustrating situation.
Old Nov 21, 2002 | 09:39 PM
pittsaj's Avatar
pittsaj
Default Re: Paint Experts (rwd)
Tha main problem is although there is no apparent damage I am afraid of wearing the paint with the constant wiping.
Old Nov 21, 2002 | 10:20 PM
Grey Ghost's Avatar
Grey Ghost
Maybe, instead of concentrated heat, extended use of low heat ? Hair dryer, portable light, etc...I have a portable light that cost about $10.00 that will absolutely fry your skin if you touch it. It is really too bright to use.
I forgot if you said this only happens when it is outside ? If so, the sun and heat is drawing it out of its hiding place. Maybe, if possible, leave the car out for extended periods of time. Cover the car except for the problem area. UV rays are what KILLS paint. I understand you wanting to protect the original paint. But, I think, IMHO, you could rub that spot the rest of your life and not hurt it. The only thing that will hurt it is UV rays or trash. If there is dirt or particles on top of the paint, when you rub it, you are GRINDING those into the paint. So, hose the area off first, or apply liberal amounts of water to the area and then rub.
Before I paint a car. I wash it down with Windex. Windex contains amonia and will clean any contaminants off the surface. If you don't and start sanding, you are just grinding those contaminates into the paint and they will come back to haunt you. You can use Windex in your problem area without hurting the original paint. It will only remove wax, etc... That is what I would try. Windex the bad area, expose to LOW extended heat source (sun, hairdryer, etc) Then, remember you will need to wax that area or car again.
Old Nov 22, 2002 | 12:18 AM
pittsaj's Avatar
pittsaj
Good thought,
I'll try that tonight..
It might help to remove the wax and let it breath..
Tony
