How do I fix this?
Old Dec 11, 2019 | 05:05 PM
esema's Avatar
esema
Default How do I fix this?
Just finished replacing all of the wiring harness installation in my '61. Everything is perfect with one exception. I installed the steering wheel without the horn assembly on and when I went to move it out of the garage the horns intermittently honked as i turned the steering wheel. Pulled the steering wheel and disconnected the horns. When I lightly push the end of the steering shaft diagonally towards the mast jacket and against the top mast jacket bearing the horn relay engages so if they were hooked up the horns would honk. The mast jacket top bearing is new as is the wiring harness it's connected to. I pulled the hub and removed the turn signal loom from the mast jacket along with the lead from the top mast jacket bearing. Reconnected the horn lead to the mast jacket bearing wire outside of the mast jacket and lightly pushed on the end of the steering shaft and once again the horn relay engaged.
Anybody have an idea of what's causing this and how to fix it? Thanks in advance.
Old Dec 11, 2019 | 09:39 PM
esema's Avatar
esema
I guess I stumped everyone
Old Dec 12, 2019 | 02:06 PM
R66's Avatar
R66
I am not a C1 guy.
Anyway, I don't have a wiring schematic to find out what hot wire feeds the horn button from the relay (I think). I am pretty sure it is hot and unfused, so I would disconnect the battery until one of the electrical gurus wake up from their nap. You don't want to burn up the new harness nor the car. If you can post a schematic, I can read most of them and give you an idea about which wire that feeds the horn button to disconnect. The proper fix is to disassemble the column again and hook it up properly in there.
I am sure one of the experts will chime in once they are well rested.
Ron
Old Dec 12, 2019 | 02:11 PM
jimh_1962's Avatar
jimh_1962
2018 C1 of Year Finalist
Shim it with a piece of paper. Seriously, I had this problem and figured out that the contact was touching on one side. I tried bending the contact but reinstalling the horn would cause it to contact. If that sounds similar. Somewhere its grounding out causing the connection. In my case it was at the horn contact where the horn button fits inside.
Old Dec 12, 2019 | 04:50 PM
Pilot Dan's Avatar
Pilot Dan
The black horn wire that should run INSIDE the mast tube and be attached to the upper bearing assembly completes the horn circuit when it touches ground, the turn signal wires have nothing to do with it. It seems you have a short to ground which is causing the horn to blow. Did you attach the black wire in the correct position on the new bearing? Did it get pinched in the tube?
Old Dec 12, 2019 | 05:45 PM
856666's Avatar
856666
Just my 2 cents but you need to be descriptive in the title of your post
Phil
Old Dec 14, 2019 | 11:53 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Old Dec 15, 2019 | 01:51 AM
K2's Avatar
K2
OK I'll take a stab at it,
A tan wire from your horn relay connects to a black pigtail connected to your upper mast bearing assembly. The horn button spring ring completes the circuit to ground when you push the button.The upper bearing contact ring must be insulated from the mast housing and the upper mast bearing, If sideways pressure on the steering shaft causes the horn to sound then a the insulation between contact ring, mast housing, and or upper bearing is compromised. With contact ring lead wire disconnected at harness and upper bearing assembly installed, take an ohm meter and touch one lead to the contact ring and other to steering shaft and you should not get continuity between the two, Now put sideways pressure on steering shaft and see if you get continuity. Repeat with one probe on contact ring and one on mast jacket.
If in either case you have continuity between the contact ring and either the steering shaft or mast housing then they are not properly insulated from the contact ring assembly,
Hope that helps you to troubleshoot the problem.
Old Dec 15, 2019 | 10:48 PM
65specialk's Avatar
65specialk
Pilot Dan you are correct.
To How do I fix this?
