Speedo gear
Old Dec 11, 2019 | 06:36 PM
Benjy's Avatar
Benjy
Cruising
Default Speedo gear
Just changed the rear end on on my 1960 from 3.73 to 3.08. Speedometer is off by about 10%. Which speedo gear do I need.
Thanks..
Old Dec 11, 2019 | 07:09 PM
856666's Avatar
856666
Read this
https://www.corvetteforum.com/forums...eedo-gear.html
Phil
Old Dec 11, 2019 | 09:27 PM
65GGvert's Avatar
65GGvert
Did you have the stock 3.70 gear in it?
Old Dec 11, 2019 | 09:37 PM
Benjy's Avatar
Benjy
Cruising
Yes I did have a stock 3.73 .
Old Dec 11, 2019 | 09:40 PM
Pilot Dan's Avatar
Pilot Dan
You can get it close, but if you want the correct speedo reading with a 3.08 which is what I have, you will need to change the transmission Driven gear to do that.
Old Dec 11, 2019 | 10:32 PM
65GGvert's Avatar
65GGvert
Stock was a 3.70.
To Speedo gear
