Protecto plate
Old Dec 16, 2019 | 07:37 AM
Spowell637's Avatar
Spowell637
Default Protecto plate
Can anyone interpret the Protecto Plate on my 67 Corvette L79?
Thanks in advance
(Moderator Edited improper photo attempt)
Last edited by vettebuyer6369; Dec 16, 2019 at 11:00 AM. Reason: I didnt know how to post photo
Old Dec 16, 2019 | 07:40 AM
90sundevil's Avatar
90sundevil
Not from that.
Old Dec 16, 2019 | 07:50 AM
65GGvert's Avatar
65GGvert
Delete all the gobbledygook and post a picture of the plate.
Old Dec 16, 2019 | 07:51 AM
65GGvert's Avatar
65GGvert
Failing that, just tell us what's on the plate
Old Dec 16, 2019 | 07:53 AM
Spowell637's Avatar
Spowell637
Sorry I cant quite seem to figure out how to delete the post.
Old Dec 16, 2019 | 08:00 AM
Spowell637's Avatar
Spowell637
420 972 194377S194 (serial number)
V0512KHH AK0216W
P7C22
Original Owner's,, address
Thanks for your patience I should have done this to start. I'm no computer guy for sure.
Thanks in advance for your help.
Old Dec 16, 2019 | 08:02 AM
65GGvert's Avatar
65GGvert
In your first post, hit edit, and then highlight all the text and hit the delete key or backspace. Type any three letters or more and then save. You can't delete the original post but you can delete the data.
Old Dec 16, 2019 | 08:15 AM
Mark Lovejoy's Avatar
Mark Lovejoy
The only info I can decode is V0512KHH per the NCRS Pocket Guide
The engine was assembled on May 12th and it's either:
KH 350HP, 1x4BC, Hi-Lift, K19, A/C, P/S & 4-speed
or
HH 300HP, x4BC, K19, & Manual Trans
K19 = Air Injection Reactor
I don't know why there are three letters after the assembly date, usually there are just two.
Old Dec 16, 2019 | 08:21 AM
65GGvert's Avatar
65GGvert
V0512KHH AK0216W
P7C22
Saddle vinyl interior, white exterior,
Coupe, Vin # (the second number after the S cannot be a 9, so double check that.
V=Flint plant (67) KHH =67 327 350hp 4B,AC,AIR,MT,PS, Holley carb engine stamped May 12th
AK= 3.36 non posi rear stamped Feb 16
Muncie 4 speed stamped 22nd day of March, 1967
Old Dec 16, 2019 | 11:02 AM
vettebuyer6369's Avatar
vettebuyer6369
I deleted out all that text, it was resulting from trying to paste a picture or some other method.
Check out the step by step directions on how to post photos in the Sticky section.
Old Dec 16, 2019 | 11:24 AM
Spowell637's Avatar
Spowell637
Thanks so much
Old Dec 17, 2019 | 07:10 AM
Spowell637's Avatar
Spowell637
I mistyped the vin should be 194377S119453 Thanks so much for all of your help
Old Dec 17, 2019 | 07:45 AM
65GGvert's Avatar
65GGvert
Approximate build date May 27th.
To Protecto plate
