[C2] Deciphering rear axle code
Old Jan 31, 2020 | 08:40 PM
Mr Fufu's Avatar
Mr Fufu
Default Deciphering rear axle code
I crawled under my '67 coupe and read the code stamped on the bottom of the differential carrier:
AW N 02 9 M
Can anyone decipher this code?
As best I know, the ratio is 3:08. But my car is an original base engine small block car with Powerglide.
I suspect a previous owner replaced the differential as it has the big-block type yokes with caps and bolts.
If my diff was changed to the big block type, what would be the advantage of doing that? Is it stronger? In what way? Does this mean I can do burn-outs without worry about blowing up the rear end?
Thanks for sharing your know how with me.
Old Jan 31, 2020 | 09:05 PM
Greg's Avatar
Greg
Just another Corvette guy
It is a 1969, 3.08:1 posi, heavy duty (427) application. The housing cast number 3899143 will confirm this info.
Old Jan 31, 2020 | 09:35 PM
R66's Avatar
R66
So, how was the BB differential different (HD) than the SB other than the U-joint straps? Same ring and pinion? Same posi-traction carrier? Housing maybe?
Just curious.
Old Jan 31, 2020 | 10:03 PM
JohnZ's Avatar
JohnZ
Just curious.
Different stub axles with bolts/straps for the U-joints. Otherwise identical.
Old Jan 31, 2020 | 10:16 PM
R66's Avatar
R66
Thanks John, I was thinking maybe they went to the 12 bolt ring gear (8-7/8") and pinion. I never could understand why they didn't put the same gears as the 12 bolt when it came out, but then again, probably bean count.
Is the corvette 8.2" ring and pinion interchangeable with the 8.2" 10 bolt from a GM passenger car?
Couldn't resist learning more while I have you on the hook.
Ron
Old Feb 1, 2020 | 08:57 AM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
Here is what I have for a quick reference.........Have a great weekend!!
Old Feb 2, 2020 | 10:06 PM
JohnZ's Avatar
JohnZ
Ron
No, the Corvette ring & pinion gears are NOT interchangeable with the passenger car 8.2" 10-bolt; I reviewed the rear axle portion of Zora's SAE presentation again, and he made no mention of why the Corvette ring & pinion was unique to the Corvette. Maybe Gary Ramadei has more info on this.
Old Feb 3, 2020 | 12:28 PM
Mr Fufu's Avatar
Mr Fufu
Thanks Greg for deciphering the code on my differential. Next I'll check the housing cast number to confirm.
What specifically are the differences between the small block diffs and the big block (heavy duty) ones?
Any guesses as to why a the previous owner would have put a HD (427) rear end in his small block car?
Old Feb 3, 2020 | 12:34 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
see post 4
Old Feb 4, 2020 | 02:56 PM
Greg's Avatar
Greg
Mr.FuFu,
Perhaps that differential was just available at the time. Probably no more to it than that. Anyway, that's a nice diff to have.
Cheers, Greg
To Deciphering rear axle code
