[C2] Offset shifter handle?
Old Feb 9, 2020 | 02:33 PM
FLYNAVY30's Avatar
FLYNAVY30
Default Offset shifter handle?
Before I pull my center console apart, I thought I'd post to see if anyone has come up with any solutions that offset the shifter handle to the center of the car. The combination of shifter location, steering wheel, and the absurdly high brake pedal in these cars means that with the shifter in reverse, 1st, or 2nd, I have a very tight squeeze lifting my (admittedly huge) leg between the steering wheel and shift ****. Being able to offset the shift lever even an inch towards the center of the car would be huge win in the comfort and ergonomics department.
My initial thought was to cut the Hurst handle (I have a Hurst competition plus) just above the two mounting bolts, then weld in a piece of metal 1 - 1.5" wide. Then grind it down, smooth everything up, make it pretty, then send it out for a brushed aluminum powder coating so that it would match the spokes on the steering wheel.
Interested in any input....this is a classic example of big guy in a little car
Old Feb 9, 2020 | 02:51 PM
Factoid's Avatar
Factoid
How you fly a helicopter with those huge tree stumps is a mystery to me! 😎
You can make a steel spacer and use longer bolts to move the shift lever to the right.
Old Feb 9, 2020 | 03:14 PM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
How close is your shifter stick when in it's in the right-most gears (4th or 5th - don't recall your tranny choice). In other words, is there much room left to push it over there?
Old Feb 9, 2020 | 04:40 PM
L36 rag's Avatar
L36 rag
Hurst actually sells replacement handles in different configurations/ offsets. maybe you can find something here.
https://www.shifterdoc.com/productca...owProductLDesc
Old Feb 9, 2020 | 05:52 PM
Bluestripe67's Avatar
Bluestripe67
Active Streak: 90 Days
Hurst does sell a Competition Plus offset shifter for Mopars, but it's tall, requiring some serious machine work. It does have a 3.9" offset. Part # 5384084, $175.00 Dennis
Old Feb 9, 2020 | 05:55 PM
Tom Austin's Avatar
Tom Austin
Greg,
By "Hurst handle" you mean the one that doesn't use the reverse lock out "T"? If so, it's the same one I used for my T5 conversion. I will tell you that the bottom part of the shifter is "billet" - it's solid! I wanted a stock appearing shifter, but wanted it slightly shorter (think Miata) than the stock shifter. So, I clamped the end plate in my vise and cut a "shoulder" in the round base and drilled holes to mount the shifter to my "L" bracket for the T5. Then, I cut the end plate off. You could do something similar . . . but using a spacer block to move your shifter to the side.
Old Feb 9, 2020 | 06:32 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
That's similar to what I did several years ago. I cut the handle about an inch above the mounting holes, welded a horizontal steel piece to the "stub", towards the right/passenger side, and then welded the vertical stick piece to the horizontal piece, offsetting the stick to the right by an inch and a half. It all hid under the shifter boot, so the modification was invisible.
This is also a good time to decide if you want to change the forward/back angle of the shifter handle too.
Old Feb 9, 2020 | 08:53 PM
FLYNAVY30's Avatar
FLYNAVY30
No dainty jet pilots here!!!
Old Feb 9, 2020 | 08:54 PM
FLYNAVY30's Avatar
FLYNAVY30
I actually ordered one that was bent to the right. I still need to offset the whole handle more.
Old Feb 9, 2020 | 08:55 PM
FLYNAVY30's Avatar
FLYNAVY30
Thanks....this is probably the route I'm going to need to go.
To Offset shifter handle?
