HEI Distributor fitting under the shielding
Old Feb 10, 2020 | 03:23 PM
Brian's Avatar
Brian
Default HEI Distributor fitting under the shielding
My 64 coupe is a driver, (no racing) I have a 400 sbc with the stock shielding. and Southwest Performance Parts has a 62-74 Tach drive HEI distributor with a 65K coil for $80. Seems like it may be Chinese junk. But they had good ratings on Amazon.
Anyone have any experience with this company and whether an HEI will fit under the Shielding?
Southwest Performance Parts has no phone contact, all email, which is a pain! All my questions have been answered pretty vague.
Old Feb 10, 2020 | 03:58 PM
Frankie the Fink's Avatar
Frankie the Fink
Army
Why would you put yourself through these gyrations? Dicey product, lame support, figment problems most likely - your car will never see nor use 65,000 volts or even 35,000 volts. I’ve learned to be cautious about Amazon ratings.
Old Feb 10, 2020 | 04:47 PM
USMC 0802's Avatar
USMC 0802
Veteran: Marine Corps
USMC
Not sure about the one you reference, but here’s the one I got from Zip for my build; fits under the shielding perfectly and is a tach drive unit as well.
https://www.zip-corvette.com/62-74-e...ach-drive.html
My car is a driver and I’ve got over 10k miles on it, no issues.
Good luck!
Old Feb 10, 2020 | 05:53 PM
Brian's Avatar
Brian
This is why I am asking you! 😂
I knew someone would answer just like you did, but sometimes you need someone to bounce things off.
That’s why I’ve been a Corvetteforum member the second week it started back in the ‘90’s.
Your critique is appreciated young man.
Old Feb 10, 2020 | 05:57 PM
Brian's Avatar
Brian
Good luck!
Excellent answers all, but I am going on your recommendation.
Thank you all for your time and input.
Old Feb 10, 2020 | 08:01 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
why not keep your tach drive points dist and put in a new electric widget to replace the points
Old Feb 12, 2020 | 06:23 PM
Brian's Avatar
Brian
Distributor is worn, so it's either rebuild it or replace it.
Old Feb 12, 2020 | 06:30 PM
Nowhere Man
I would think rebuilding it would be a whole lot cheaper and you can control the quality much more
Old Feb 12, 2020 | 09:48 PM
wilcar's Avatar
wilcar
I had advanceddistributors.com in Shakapee, Mn rebuild and recurve one sbc and one pontiac points distributor. $229 for each. Not sure if anyone makes new distributors in the USA with USA made parts! My 2 cents says keep your original unit! Core charge at rockauto is $150 on a cast iron distributor like yours.
Old Feb 12, 2020 | 10:09 PM
Brian's Avatar
Brian
I could see keeping it if it was original motor, (400 cu in small block), but I can buy a brand new HEI for $170 (plus new coil and wires) which should perform nicely. (the one recommended in earlier post).
Although, I have concerns about Chinese products, so that's a factor.
I'll look around for a rebuilder.
Thanks for you input everyone.
Old Feb 12, 2020 | 10:23 PM
LouieM's Avatar
LouieM
Dave Fiedler rebuilt my stock 67 distributor 10+ years ago, no issues since then. He put in a new shaft, new cam atop the shaft for my engine combination, etc.
http://www.tispecialty.com/consulting.htm
Old Feb 13, 2020 | 02:37 PM
kingwoodvette's Avatar
kingwoodvette
Good luck!
Dont believe this is HEI. It just has an electronic replacement for the points.
Old Feb 13, 2020 | 02:55 PM
dmaxx3500's Avatar
dmaxx3500
try this one I found on e bay
small cap w/tach drive
eBay item number:
202251380240
To HEI Distributor fitting under the shielding
By Michael S. Palmer | 2026-06-03 11:00:24
