John
Old Feb 12, 2020 | 10:24 AM
John M Steffen's Avatar
John M Steffen
3rd Gear
Default John
Hello can anyone tell me does a L88 427 use a thin top piston ring Trying to determine if I have a L88 it has the extra plug for the oil cooler 7/16 rod bolts and 12.5:1 pistons date code H 28 9 casting #3963512. CE067152. With iron heads 3919840 E 15 8 GM 4T I understand doesn’t have aluminum heads but wondering about block
Old Feb 12, 2020 | 11:42 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Hi, moved your post here in the C2 section, should reach the right people here.
Old Feb 12, 2020 | 12:43 PM
Avispa's Avatar
Avispa
AFAIK, they're supposed to be 1/16" inch top and second compression rings. Other 427s (L72/L72/L36) have 5/64" top and second compression rings.
Old Feb 12, 2020 | 12:55 PM
vettebuyer6369's Avatar
vettebuyer6369
John, in the future, think about entering a subject title that describes the content of your post, so people will have a reason to click on it and possibly answer questions you may have. Entering your first name is not informative.
To John
