Harmonic Balancer Question
I replaced my BB camshaft this past weekend. Went from a 262 duration to a 223 duration for improved idle. Also, solved my dieseling problem as I lowered the idle speed.
Anyway, during the teardown we discovered that the harmonic balancer is only a 7 inch balancer. The pro that was helping me said I should have an 8 inch.
I'm dealing with a 1974 block/crank 454 that was transplanted into my '66 coupe.
So, do I need to replace it with the proper 8" balancer or let it go? I'm not racing, if that's an issue.
Thanks in advance for the advice.
Plowboy :cheers:
My guess is that the 454 was a short block rebuild and they took the 427 7" balancer & slapped it on the 454. Too bad the 427block has disappeared but was probably trashed anyway.
I'm thinking I can get by w/ the 7" balancer for now unless I hear anything too negative.
I may put the car back to 'the numbers' eventually. That will depend on the cost vs benefit. For now I'm just enjoying the ride. :cheers:
Plowboy
396,402,427 engines are internally balanced and have a neutral balance balancer and flywheel. 454s should use a 454 balancer and flywheel.
otherwise it will vibrate.
1973 GM parts book calls out p/n :
3963529 for '70 454 (ex HD) and '71-'72 with High Perf 454
3963530 for '71 with Sp. High Perf 454
330849 for '73-'74 454 Corvette's, '73-'76 Chevrolets, '76-'84 Chevy p/u's (probably '73-'84)
Would you be able to shed light on the three GM part numbered balancers : diameter , width's and weight's ?
I also have a three 454 balancers :
date code :
03474 - stamped 3530H
054 79 - stamped H 3530
348 83 - stamped H3530
Is the H3530 / 3530H stamping the last four digits of the p/n as one usually expects ?
I know GM listed balancer p/n 3963250 in the old "Stopwatch" Book and in the following Chevy Power Books as the recommended balancer for Hi-Po 454 (LS6 LS7) applications.
I find it hard to believe that I may have have three of the Hi-Po 454 balancers ?
I wonder if these may actually be the 330849 regular production line installed units based on the date codes ?
Thank you,
Jerry
date code :
Thank you,
Jerry
Thanks much for the reply.
The P&A books just state applications.
Oh well on to other possible resources
Jerry
