Vent window adjustment
Old Mar 25, 2020 | 09:11 PM
vipervetteguy's Avatar
vipervetteguy
Default Vent window adjustment
Brought a 66 vert restomod home today. Noticed that the right vent window doesn’t close tightly. I can see a bit of light through seal and I can manually feel the glass needs to pivot several more degrees. Before I take the door panel off I figured I’d ask about what I’m getting into. Will I find adjustments, limiters, etc. ?
Old Mar 25, 2020 | 09:25 PM
dcamick's Avatar
dcamick
2019 C1 of Year Finalist (appearance mods)
A vent regulator rebuild.......Not that difficult........It's probably harder to take the door panel off.....
Kits are available.....I did both on my 65....and they were both BAD!
Old Mar 26, 2020 | 08:20 AM
DansYellow66's Avatar
DansYellow66
In addition does it look like the vent weatherstrip may have been replaced in recent years. If so it's typical that there is a lot of resistance to the glass seating in the seal at firs and the glass needs some push while turning the crank. On mine, it took several years but finally the vent seal conformed to where it would close normally. But as noted damick if the regulator gears are worn that will be working against you too.
Old Mar 26, 2020 | 12:26 PM
C2Scho's Avatar
C2Scho
Vipervetteguy,
Here is a link below to what you likely will need. Don't forget that there is a difference in your order for a coupe versus a convertible. Like dcamick said, taking the regulator out and putting it back in is much more difficult than actually doing the rebuild of the worn/broken regulator. Good Luck with it. C.J.
http://www.corvetteusa.com/vent.html
Old Mar 27, 2020 | 05:48 PM
C2Scho's Avatar
C2Scho
Here is a link to someone here on the Forum selling exactly what you may have to take out of your door and rebuild. Or you could buy a new pair from this gentleman and not worry about doing a rebuild.
https://www.corvetteforum.com/forums...lators-pr.html
To Vent window adjustment
