Prothane Spring Bushing Problem.
Old Apr 3, 2020 | 06:03 PM
Larphred's Avatar
Larphred
Default Prothane Spring Bushing Problem.
Nothing goes right on this project.
I purchased new rear leaf springs for my 1959 roadster. I bought Prothane urethane bushings for the springs. The shackle bushings fit, but the front spring bushings have “lips” that protrude from the front spring eye that will not allow the spring + bushing to fit into the hanger. I can remove the “lips” with my bandsaw but am unsure how to proceed. Intuition tells me to remove the inner lip so the head of the hanger pin will engage with the hanger hole.
anybody else experience this dilemma?
Thanks.
Old Apr 3, 2020 | 06:56 PM
jim lockwood's Avatar
jim lockwood
C2 of Year Finalist (track prepared) 2019
Consider getting rubber bushings and tossing those poly bushings in the trash.
Old Apr 3, 2020 | 07:45 PM
Larphred's Avatar
Larphred
You don’t like urethane, eh? May I ask why you prefer rubber, as I respect your advice?
So, here’s another? This was gonna be a dad n lad project, but lad got a good job which wears him out, so it has become a 71 year old dad project. Dad needs surgery on his rotator cuff (supraspinatus tendon 90% toast) but can’t get surgery during this crisis. So it was very difficult for me to get the urethane bushings in the shackles and install the rear of the spring.
What is your opinion of running urethane at the rear of the spring and rubber on the front of the spring? Mismatch?
thank you for taking your time to respond.
Old Apr 3, 2020 | 09:11 PM
jim lockwood
My dislike of poly bushings stems from their long standing reputation for self destruction in even normal use. In contrast, rubber bushings last a good long while, measurable in decades.
Old Apr 3, 2020 | 09:20 PM
Larphred's Avatar
Larphred
Thanks. Perhaps I’ll keep the prothane on the rear, rubber in front and replace the prothane after surgery.
any ideas on bending leaf spring to fit the front hanger in place?
Old Jan 26, 2026 | 09:43 AM
Bear78Indy's Avatar
Bear78Indy
Cruising
[QUOTE=Larphred;1601255312]You don’t like urethane, eh? May I ask why you prefer rubber, as I respect your advice?
thank you for taking your time to respond.[/QUOT
I just did two C3s that I have a 78 PC and a 79 I put Polys on both front and back and I used shorter bolts on the 79 as I wanted a little Rake in the stance... Ride is nice and firm, time will tell how they hold up. I agree the scissor jack no jack stands is a bit dangerous
Old Jan 26, 2026 | 09:44 AM
Bear78Indy's Avatar
Bear78Indy
Cruising
Old Jan 26, 2026 | 10:27 AM
Limp's Avatar
Limp
Poly bushiings don't seem to do well in applications where there is a twisting action... Front A Arm bushings, and rear leafs are a common complaint area...
Old Jan 26, 2026 | 11:26 AM
R66's Avatar
R66
I only used Poly bushings once in a 4 link rear suspension and they crumbled and failed within 1,000 miles. I would advise you to stick with rubber.
Ron
Old Jan 27, 2026 | 04:40 AM
ghostrider20's Avatar
ghostrider20
Ron
Had that happen with camber rods poly bushings.
The late JohnZ explained that most suspension joints need spherical compliance although at first glance there action may be only in a single plane, it's not. I've ridden in several "hot rods" with poly in every location and they wrote like **** and squeaked.
Old Jan 27, 2026 | 07:20 AM
DansYellow66's Avatar
DansYellow66
The only place I use poly is in sway bar bushings.
To Prothane Spring Bushing Problem.
