Kleanstrip.
Old Apr 11, 2020 | 07:58 AM
hcallaway's Avatar
hcallaway
Default Kleanstrip.
AIRCRAFT® FIBERGLASS PAINT REMOVER
This product has been discontinued.
WARNING: This product can expose you to chemicals including Methylene Chloride, which is known to the State of California to cause cancer, and Methanol and Toluene, which are known to the state of California to cause birth defects and other reproductive harm.
This product really worked great. I used the last of my 2 gallons and bought the replacement last week. I got ready to apply it and I noticed the labeling had changed. It specifically said not to use on fiberglass. I had the old process of stripping down to a science. I have started to sand using 120 as my most aggressive grit. I have seen others tout 80 grit. No matter what process this is not going to be fun as I still need to strip the top and bottom of my hood. The old original lacquer brown primer loves to gum up when it is wiped down with thinner. Now what any suggestions. I know this topic has been beat to death, but this is the first where I found out an option had been removed. What other chemical strippers have been used?
Old Apr 11, 2020 | 10:29 AM
tgtexas02's Avatar
tgtexas02
Thank goodness my 58 body was striped when I bought as a project. I did use this striper on donor quarter panel, decklid and lower nose section. Loved the stuff. I have been looking for it to to clean up interior side of a donor door. Now I know why I cannot find it anywhere.
Old Apr 11, 2020 | 10:40 AM
Pop Chevy's Avatar
Pop Chevy
2021 C1 of the Year Finalist - Modified
I am using Citristrip from Walmart . It works , but slowly and 1 layer at a time.
Old Apr 11, 2020 | 10:44 AM
elwood13's Avatar
elwood13
Holt, I can stop by paint store next to work on Monday and see if they still have the old stuff. Not sure if they will be open but I will try. The next hurdle is can I ship it?
Old Apr 11, 2020 | 12:04 PM
pop23235's Avatar
pop23235
This is what I use. Todd used it on the 64 as well. Red oxide is tough to remove.
Old Apr 11, 2020 | 05:04 PM
hcallaway's Avatar
hcallaway
Default Discontinued that the problem.
What a great product just dangerous.😃
Old Apr 11, 2020 | 05:05 PM
hcallaway's Avatar
hcallaway
Default I bet shipping would be an issue!
i would love to have it.
Old Apr 11, 2020 | 05:11 PM
hcallaway's Avatar
hcallaway
Default The old way.
Old Apr 11, 2020 | 09:17 PM
pop23235's Avatar
pop23235
Is this the discontinued one? Can’t recall where I bought it, but not too long ago. May have been Tractor Supply.
Old Apr 12, 2020 | 12:48 PM
vettebuyer6369's Avatar
vettebuyer6369
Do they still sell Cap’n Lee’s?
Old Apr 12, 2020 | 09:10 PM
pop23235's Avatar
pop23235
Holt, got it at O’Rileys.
Old Apr 12, 2020 | 10:24 PM
elwood13's Avatar
elwood13
I’ll check the paint store tomorrow if they’re open. I’ll pick up a couple cans if they have it in case someone needs some.
pop, did it have that bluish green ribbon like the can above or a light blue one instead?
Old Apr 13, 2020 | 09:51 AM
elwood13's Avatar
elwood13
Just checked my paint store and they are sold out.
Old Apr 13, 2020 | 11:31 AM
pop23235's Avatar
pop23235
That is a pic of the can I purchased at O’Riley’s.
Old Apr 13, 2020 | 01:49 PM
Ken Sungela's Avatar
Ken Sungela
Methylene Chloride was banned by the EPA for consumer use in early 2019. Klean Strip has a new version less the M.C. http://kleanstripauto.com/products/a...remover-liquid
It will take longer to lift off the paint. I haven't tried it yet.
Old Apr 13, 2020 | 01:54 PM
juanvaldez's Avatar
juanvaldez
Anyone use soda blasting to strip paint from fiberglass?
Old Apr 13, 2020 | 05:28 PM
Pop Chevy's Avatar
Pop Chevy
Cap'n Lees is loooong gone and sorely missed ! Best stripper I ever used.
To Kleanstrip.
Old Apr 13, 2020 | 07:58 PM
hcallaway's Avatar
hcallaway
Default Soda Blasting
I think it is very effective. On metal cars the residue can remain in seams and cause problems if not properly neutralized. Many paint shops avoid painting a car that has been soda blasted. I have read how some Corvette shops hold the same views.
I am looking into the exterior of my hood. I have not been able to get any responses with the current world environment.
Old Apr 13, 2020 | 08:08 PM
hcallaway's Avatar
hcallaway
Default Specifically noted not for use on fiberglass.
Cap'n Lee's and Klean Strip are sadly no more. I am going to try Citristrip tomorrow, but it also notes not for fiberglass. I am going to do a small test patch and time it.
Dub made a great impact on me on how to test and really try to understand what works and how it works. I hope I am not butchering his views.
Attachment 48343716
I can only guess how long and how many hours it has taken to get it to this point.
The top side of the hood had now been sanded to the point where the paint is very thin in most areas. I am hoping that with a little Chemical effort the remainder will be removed and then I can wipe it down with acetone and/or lacquer thinner.
Old Apr 13, 2020 | 09:23 PM
elwood13's Avatar
elwood13
I’ll check the orileys by me tomorrow and see if I have any luck. I think I can ship it fedex or ups.
